Thread: How to read the AFR on wideband?
Results 1 to 5 of 5
  1. #1 How to read the AFR on wideband?
    Aug 2008
    SOUTH TEXAS
    Hey guys, im still trying to figure my AEM wideband out.
    To scan the AFR, do i scan going from WOT?
    Or will it be the same doing a scan from let say 60mph?
    I went WOT this morning and it read 10.4-10.5.
    And rolling it read 10.9 then it went down to 10.5.
    Any input is appreciated!
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  2. #2 Re: How to read the AFR on wideband?
    WOT is the value youre most concerned about.
    youre still running really rich. i think you need to back off a pulley size and lean the car WAY out. it will feel much faster running on a better AFR.
    your AFR at WOT should be in the mid 11s. even with my meth i still only hit 11.0.
  3. #3 Re: How to read the AFR on wideband?
    Aug 2008
    SOUTH TEXAS
    If you dont mind me asking, why back off a pulley size to work on my AFR?
  4. #4 Re: How to read the AFR on wideband?
    Barksdale AFB, LA
    Quote Originally Posted by GTP4 View Post
    Because if you back off on the fueling now you'll start getting more knock.
    2009 Subaru Impreza WRX STI
  5. #5 Re: How to read the AFR on wideband?
    you need less pulley and less fuel. once your fueling is dialed in THEN try to bump back down to where you were and add a little fuel.
    youre running stupid, pig rich right now.
  1. Wideband AFR where should....?
    By GTP4 in forum PCM Tuning
    Last Post: 04-21-2009, 11:57 AM
  2. Anyone run an LC1 Wideband...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 03-24-2008, 09:41 PM
