Thread: pcm help with tranny swap
Results 1 to 9 of 9
  1. #1 pcm help with tranny swap
    Apr 2009
    Georgia
    hey i just put a tranny from a 97 gp into my 200 gpse 3100. i understand that i need to have my pcm re programmed. is it safe to drive it to a mechanic to have them program it. do i need to have it towed or is there a cheep way that ican do it myself at home.
  2. #2 Re: pcm help with tranny swap
    GT Level Member GPSims39's Avatar
    Nov 2008
    Hauppauge, NY
    only way to do it cheep from home is to get a hypertech like tuner to plug into yoru pcm and make the changes yourself, but you need to know the exact ratio you are changing it to, other than that you have as i stated in your trans post, 1) send it off to be re-programed, 2) get a 97 pcm 3) get a whole new pcm programed to your liking.
  3. #3 Re: pcm help with tranny swap
    hypertech-what?
    you need someone with a DHP Powertuner or HP Tuners.
  4. #4 Re: pcm help with tranny swap
    Nov 2008
    Hauppauge, NY
    i said Hypertech LIKE Tuner, i know better reading on here than to suggest a hypertech unit to someone, i will get torched.
  5. #5 Re: pcm help with tranny swap
    Barksdale AFB, LA
    Quote Originally Posted by ddyke2000 View Post
    Most mechanics won't be able to do it for you. It requires a HPTuner suite or a DHP Powrtuner. Even a dealer won't be able to do it since their Tech2 isn't designed for that sort of thing.
    2009 Subaru Impreza WRX STI
  6. #6 Re: pcm help with tranny swap
    Apr 2009
    Georgia
    so i think it will be easier to get a pcm from a 97 gp. is there any certain 97 gp pcm i need to get. also the pcm is the same as the ecu correct. i believe my tranny is the 4t65 hd. i did not know if it would make a diference.
  7. #7 Re: pcm help with tranny swap
    Barksdale AFB, LA
    There is no PCM that will work with your 3.1L and have the 2.93 gear ratio of the 4T65E-HD tranny already programmed in. No matter what you'll have to do some PCM programming with tuning software.
  8. #8 Re: pcm help with tranny swap
    Apr 2009
    Georgia
    Two things, is it safe to atleast start the cars and drive in first. Also does anyone know of any performance shops here in georgia in the south metro atlanta area?
  9. #9 Re: pcm help with tranny swap
    Barksdale AFB, LA
    You can drive it, but it won't shift at the right points and will start banging into gears as it shifts once the PCM sets the trouble code. This would've been a lot easier if you had just found the right tranny and sold that HD. The "HD" part isn't really going to do anything for you.
  1. Tranny swap
    By kbradley in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2009, 07:45 AM
  2. Help!! Tranny Swap Engine ''Refresh''
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-10-2008, 12:04 PM
  3. Getting ready to swap the tranny chain...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-22-2008, 10:49 AM
  4. top swap
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2008, 04:23 PM
