Thread: Boost Control?
Results 1 to 4 of 4
  1. #1 Boost Control?
    SE Level Member RicerKiller's Avatar
    Feb 2009
    Alabama
    Does anybody with an HPTuner know what you can do with the boost control option. Its under the VCM tab and I was just wondering what exactly it does. can you actually use it to increase the amount of boost you are getting? If so I understand it probably wouldn't be a good idea to increase it by much, but just thought it would be cool. thanks.
  2. #2 Re: Boost Control?
    Barksdale AFB, LA
    You can probably use it to lower it. But normally you're running at full boost. It only pulls boost as a safety measure.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Boost Control?
    Like when you get KR...the PCM pulls timing so you're car won't blow up
    Could it be connected to that by chance?
  4. #4 Re: Boost Control?
    Feb 2009
    Alabama
    ok cool i read something related on the hp tuners forum, about boost dumping, but wasnt sure if it was the same option. thanks guys.
  1. BOOST issue
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2011, 02:24 PM
  2. only 4 lbs boost???
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2009, 04:50 PM
  3. boost??
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 06:59 AM
  4. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  5. More boost?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 07-25-2008, 12:33 AM
