Thread: obd1
Results 1 to 15 of 15
  1. #1 obd1
    GT Level Member bkaab's Avatar
    Adrian MI
    What is out their for obd1's?
    '01 GP GT Topswap GT
    '95 GP GTP 3.4DOHC V6
    '95 GP SE Gone but not forgotten.
  2. #2 Re: obd1
    Oklahoma
    The dumpster, LOL
    Okay, that was a joke, you gotta work with me here.
    You mean in the way of code reading or tuning or what specifically.
  3. #3 Re: obd1
    Adrian MI
    code reading for obd1.5 mostly
    What can i get to tune it
  4. #4 Re: obd1
    Oklahoma
    I believe, and dont quote me, that most of your garden variety code readers out there will work on ODB I. They will state on the package and many of those you can get for under $100.
    As for tuning an ODB I, that I have no clue about. Hopefully someone with more insight than I in that area will step in and let you know.
  5. #5 Re: obd1
    GT Level Member BackInBlack's Avatar
    Vermont
    Reading OBD-I codes was easy. Just jam the paperclip into the diag port and watch the SES light blink. OBD-1.5 was the bastard child of GM. I've not seen many code readers that would touch it, especially 1994 +/- a year. OBD-II+ can be read easily by any of the available over-the-counter units. Most programming for the OBD-I/1.5 stuff was done with EEPROM burning, right?
    The GPs are long gone...
  6. #6 Re: obd1
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Quote Originally Posted by BackInBlack View Post
    IIRC, there were also some that were actually OBDI programming, but had the OBDII data link connector, not the ALDL plug. so a custom harness would net you a working scanner.
    but i do believe that eeproms/chips must be employed for any sort of 'tuning'
  7. #7 Re: obd1
    Oklahoma
    Man, it has indeed been a long time since I had to mess with any of that, I forgot all about the EEPROMS. Ive never dealt with ODB-1.5 or really knew about it for that matter.
  8. #8 Re: obd1
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    I'd check out TunerPro. Its free for the software and I believe should work for you since you have a 95. TunerPro and TunerPro RT - Professional Automobile Tuning Software (<--- Click that, doesn't show up as a link with the new skin)
    In the definitions, you'd need the $1FA bin file.
  9. #9 Re: obd1
    SE Level Member Incomudrox's Avatar
    New Holland, PA
    I believe the reason GM came out with OBD-II was because they had to many problems with OBD-I not and the cost of having to replace PCMs with problems. Because OBD-I PCMs where like CD-Rs write once. This was killing them so they came up with the new memory to allow PCMs to be reflashed by dealerships.
  10. #10 Re: obd1
    Banned
    New Port Richey Florida
    Nope there is a site were you can download tunning software its called tuner cat and they go all the way up to 96 so check that out and see what happens
  11. #11 Re: obd1
    SW Chicago Suburbs
    Quote Originally Posted by Incomudrox View Post
    ummm no. sorry. OBDII isnt a GM thing, it's an auto industry thing. It's just more advanced logic system, allowing for better engine management. the programmable PCM's just come along for the ride.
  12. #12 Re: obd1
    Oklahoma
    And now, of course they have went to CAN.
  13. #13 Re: obd1
    Adrian MI
    Quote Originally Posted by TyroElite View Post
    Where do I get the cord to plug into the car?
  14. #14 Re: obd1
    Williamsport, PA
    I'd suggest you check out their forums there. The tuning on OBD1 is a little different bc you need to be able to burn an PROM. THe standard PROM is not usually an EEPROM (Electronically eraseable PROM). In order to do your scanning and such, you need basically just any ALDL connector you can get from ebay or any number of links. (TunerPro and TunerPro RT - Professional Automobile Tuning Software)
    You could look into the "Romulator" which lets you emulate your standard PROM and then make changes and such on the fly. Its a bit more involved but it would be sweet.
  15. #15 Re: obd1
    I live here. UR LOSN's Avatar
    Rockford, IL
    Tuner Cats is a very good program! I used that for tuning on the LT1 then switched to LT1 edit.
