Thread: need dhp bin file
Results 1 to 9 of 9
  1. #1 need dhp bin file
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    hi i am in need of a dhp bin file for a top swaped gt with 3.8 pully l67 map gtp injectors and tb plog and dp and egr code deleted and rear o2 enabled thanks
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: need dhp bin file
    those dont really exist...
    Most consider top swap modded to the point where you MUST have a custom tune.
  3. #3 Re: need dhp bin file
    well then can some one send me a bin file for a top swap with simalar mods
    sold 97 GTP stock
  4. #4 Re: need dhp bin file
    Portland Oregon
    You can run with it by using an L67 bin with a little timing pulled and your gearing set properly.
  5. #5 Re: need dhp bin file
    Quote Originally Posted by OH4CompG View Post
    Thats whats been done in my car.
    My memory sucks.
  6. #6 Re: need dhp bin file
    @OP
    You have a tuner right? PT, HPT, TunerCat?
    If so, I might be able to get you started.. But you will need to do the fine tuning for fuel on your car or it would have to be made intentionally rich.
  7. #7 Re: need dhp bin file
    ya i got the dhp pt but i am new and dont wanna mess around to much with tuning so i just wanna get someones bin that work so i dont gotta mess with it just scan it
    sold 97 GTP stock
  8. #8 Re: need dhp bin file
    Well, I can make you a modified copy of your stock bin.. Stock GT trans section, Stock GTP engine section. But either case will require some tuning. Stock settings for either section are far from perfect and I do not have the time to go through and tune for multiple people right now. This would get you going though as the engine section would be closer to what you have and the trans section would be as good of a starting point as you could get for your transmission.
  9. #9 Re: need dhp bin file
    GT Level Member rmcardle3's Avatar
    Houston, TX
    Could you get me started with a BIN file based on my first PCM read? I got a file error the first time I tried to OPEN the Bin file. I have the error message and the actual been file but the Bin I read is "invalid", can't use it? This would just be to get me started? What would you need? Oh, I do have a DHP pt also (figured you got that). Thanks.
    2000 GRAND PRIX GTP (Sedan)
    MICHELIN Pilot® Sport A/S Plus 245/50 ZR16 97W M+S
    Cone Intake, SD Headers
  1. Cant write file to PCM Please help
    By Kasey in forum PCM Tuning
    Last Post: 10-22-2010, 09:20 AM
  2. BIN File
    By Dragon1972 in forum Off Topic Discussion
    Last Post: 09-10-2010, 04:51 AM
  3. Does anyone have a 01 GTP stock pcm file
    By gtpracer0186 in forum PCM Tuning
    Last Post: 09-02-2010, 06:13 PM
  4. DHP file
    By TheOtherNick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-25-2009, 02:51 PM
  5. pre made bin file.
    By blowfishRus6 in forum PCM Tuning
    Last Post: 04-25-2009, 01:50 AM
