Thread: Speed Limiter
Results 1 to 4 of 4
  1. #1 Speed Limiter
    Athens
    I Got A 97 Gp Se...i Was Wonding If I Could Take The Speed Limiter Off And How To...dont Know Much About Gp
  2. #2 Re: Speed Limiter
    GTX Level Member webracin's Avatar
    Arkansas
    Yes you can, however you need a power tuner or a HP tuner. The setting is in the PCM (the reason I moved your post to this section).
    The speed limiter is there because of the speed rating on the tires that were on the car from the factory....If your tires had a speed rating of S, then your limiter was set to 118mph.
    with a Power tuner or a HP Tuner, you can change that value to 255, but make sure you have tires to go that fast, or a blowout at those speeds could be nasty.
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  3. #3 Re: Speed Limiter
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    speed rating is over rated you can get an s and run 150 if you wanted cause i doubt you will do 150 for longer than 5 min. when the test them lets say they test an s rated tire they run that tire at 118 for like 5 hours or something like that. if you do 118 for 5 hours YOU DA MAN(or woman)
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  4. #4 Re: Speed Limiter
    Arkansas
    Very true, and I am not sure of the exact test they use, however I can tell you that there is a big safety factor built in. If you have S rated tires and doing 90 and have a blowout, you can try to go after the tire manf. If your doing 120 at the time of the blowout, you dont have a prayer
    With that said, if you decide to go over the speed rating, your on your own...some tires can take it some cant.
    webracin
    2001 Grand Prix GTP
