Thread: Top Swap Re Flash problem
Results 1 to 3 of 3
  1. #1 Top Swap Re Flash problem
    May 2008
    Ok, we did a top swap on my car yesterday and while reflashing my pcm, all of a sudden some relays started freaking out and my mph went up to 20. were reading 12.5 volts from the battery while on accessory, but my volts gauge inside my car (which is spliced into pink wire under dash) is reading about 9-10 volts. we reflashed a new pcm and it didnt seem to freak out during flash, but same problem with relays and mph. it also will not start.
    PLEASE HELP ASAP
  2. #2 Re: Top Swap Re Flash problem
    sounds like the voltage is too low so the write wasnt properly done.
  3. #3 Re: Top Swap Re Flash problem
    TDCRacing
    Guest
    HPT or DHP?
    If the voltage system was too low I know with HPT it will not do the write.
    Still using the same PCM or?.....
  1. Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    By LowlyfeGTP in forum Visual/Body Modifications
    Last Post: 06-26-2012, 03:14 AM
  2. re wire flash to parking lights
    By gotboost3 in forum Visual/Body Modifications
    Last Post: 01-20-2011, 05:08 PM
  3. re-wire your locking flash to your corner lights
    By GAFF in forum Visual/Body Modifications
    Last Post: 02-11-2009, 11:46 AM
  4. DIC swap
    By chrissbee77 in forum General Tech Discussion
    Last Post: 12-13-2008, 04:29 PM
  5. Reroute security system flash to parking lights on 2004 grand prix
    By Jusplayn in forum Visual/Body Modifications
    Last Post: 05-16-2008, 12:59 AM
