Thread: DHP PowrTuner on Windows 10 success
Results 1 to 13 of 13
  1. #1 DHP PowrTuner on Windows 10 success
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    Not sure if anyone else has done this, but the general idea is that you need to download the ancient version of some software to ensure the DHP v1.23 (1.24) can run.
    (PowrTuner/PowerTuner software linked elsewhere here, but feel free to discuss other install/use info that hasn't been mentioned recently)
    Some of them I had on old drives, others I had to dig out...
    DotNET v1.1 - Download Microsoft .NET Framework Version 1.1 Redistributable Package from Official Microsoft Download Center
    Jet DB 4.0 - Download Jet 4.0 Service Pack 8 (SP8) for Windows Millennium Edition (KB829558) from Official Microsoft Download Center
    MDAC 2.8 - Download Microsoft Data Access Components (MDAC) 2.8 SP1 from Official Microsoft Download Center
    Keyspan (Tripp Lite) driver - USA19HS | Tripp Lite
    You may get some questions from Win10, but just install as-is rather than compatibility, etc. If something here doesn't work for you, feel free to bring it up to the handful here still messing with these.
    This was my last time probably installing this, and will go to HPT at some point, since DHP (Charles) has faded into the background while HPT still goes on. Plus, I have a couple other vehicles that will enjoy some tuning.
    - Dave
  2. #2 Re: DHP PowrTuner on Windows 10 success
    Kemmerer, Wyoming
    sometimes you need to run the program as the administrator too
  3. #3 Re: DHP PowrTuner on Windows 10 success
    The Boss Iceman6669's Avatar
    Jun 2011
    Ahh DHP... There are still several things I prefer to that over HPT.
    2011 F-150 Yote powered
  4. #4 Re: DHP PowrTuner on Windows 10 success
    GT Level Member mguzzo's Avatar
    Buffalo NY
    i keep an old netbook (Dell Mini10V) running WinXP, it small, lightweight, plays well with the serial -> USB adapter, etc.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  5. #5 Re: DHP PowrTuner on Windows 10 success
    Feb 2017
    Riverview FL
    I've been able to run DHP PowrTuner on a Windows 10 laptop. Same software setup as dezldave961, on a Lenovo Thinkpad T450s.
    Only issue is when doing logging, sometimes it doesn't want to save the log file.
  6. #6 Re: DHP PowrTuner on Windows 10 success
    Banned
    May 2008
    Ya, I recall that being a bug in the scans. I used to bounce between UVScan and PT scanning, depending on which I liked setting up more. PT was good for large gauges, although you can increase row size in UV, too, but it's less bold.
    I'll update with any issues when I'm back up & running soon.
  7. #7 Re: DHP PowrTuner on Windows 10 success
    Oct 2014
    portland oregon
    I may try this. I'm getting rdy to install a meth set up.
    I have windows 7 laptop and a dhp with 0 tuning exp.
    Sent from my SM-N920V using Tapatalk
  8. #8 Re: DHP PowrTuner on Windows 10 success
    ive got my dhp set up on win 7, works just fine.
  9. #9 Re: DHP PowrTuner on Windows 10 success
    Kemmerer, Wyoming
    Quote Originally Posted by wowitsfast View Post
    you'll want to use a wideband so you can see actual air fuel ratios.
  10. #10 Re: DHP PowrTuner on Windows 10 success
    Oct 2014
    portland oregon
    I have one.. Thanks!
  11. #11 Re: DHP PowrTuner on Windows 10 success
    Banned
    May 2008
    Yep, did the same thing to get PT running on my Win7 laptop 5-6yrs ago. Should work out.
  12. #12 Re: DHP PowrTuner on Windows 10 success
    May 2008
    Schuyler, NE
    I've been using DHP on windows 10 for the last year. All I did was install 1.24 version and dotnet 1.1 framework and I had no problems. But I just got a new laptop that I haven't tried it with yet, so we will see how that works.
  13. #13 Re: DHP PowrTuner on Windows 10 success
    SE Level Member nitehawkjcb's Avatar
    Feb 2015
    NC
    I know this is an old thread, but it certainly helped me get this DHP to communicate with my Win 10 laptop.
    Thank you everyone in this car community.
  1. Cant get DHP powrtuner to work windows 8
    By GTPMidknight in forum PCM Tuning
    Last Post: 04-06-2015, 10:46 AM
  2. topswap fails vs success
    By Grimsin in forum General Grand Prix Discussion
    Last Post: 05-15-2013, 09:46 PM
  3. REPAIR Painting success
    By Coolride in forum Detailing Tips and Tricks
    Last Post: 04-20-2011, 07:24 PM
  4. Powrtuner w/ Windows 7 64bit
    By xxmattfxx in forum PCM Tuning
    Last Post: 10-27-2009, 10:45 PM
  5. BGPM '09 - A success, again.
    By Swash in forum Shows and Events
    Last Post: 09-18-2009, 12:49 AM
