GTP Level Member
05-10-2019
Hi Folks,
I just tuned my car for e85 using the method in the sticky (i think) and filled it up with 14.5 gallons of Ethanol. Unfortunately my Gas gauge lied telling me the car was empty.
Id love to have someone check the tune I did and see if i actually did what i was supposed to. (changing the injector gain by cylinder to 1.3)
I am a bit skeptical because I flashed the car, realized the pump i was at was Out of order, and had to start the car and move to another pump. The car had not indication of being different.
Another concern is that i adjusted the injectors to 1.25 to adjust for not being on pure ethanol. The LTFT was really high, like above 10 on my drive home.
2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
05-10-2019
You can add a copy of your tune to your post so that others can open it and see what it looks like to verify it for you.
2011 F-150 Yote powered
05-10-2019
to tune for E85 you only change the cylinder gain to 1.3. do you have facebook?
GTP Level Member
05-10-2019
GTP Level Member
05-10-2019
![Quote](https://www.grandprixforums.com/images/redfox/misc/quote_icon.png)
SgtMarshal
Unfortunately not. I deleted it a while ago, and havent looked back.
05-10-2019
so what did you change exactly?
GTP Level Member
05-10-2019
I think* I changed the injector gain by cylinder to 1.3. I fiddled with the fan turnon on and a few trans settings too
05-11-2019
I think it's running rich because of two things: one, you set your cylinder gain too high for the ethanol content of the fuel, and two, you still have gasoline in your system.
I think you did it right assuming the ethanol content of the E85 is actually 85%, which I doubt it is. It was always 70% for me.
GXP Level Member
05-11-2019
Give it some time. Ltft's should get closer to 0.
GTP Level Member
05-16-2019
GTPpower
I put about 100 miles on the car and fuel trims, especially under boost are reading in the positive. Under boost the car was showing 11%. I used HPT to clear the LTFT and it very quickly learned back into the positive.
If i remember correctly positive fuel trim means the car is adding fuel right? that would mean its running lean. Could my fuel filter be clogged? i was running an e30-40 blend for about 2 tanks prior to the almost full e85 tank.
I am just a bit worried about leaning the car out. I changed the injectors to 1.33 and it seemed to calm it down quite a bit. But that is way more than what my ethanol content should dictate.
i added a quick log i took if anyone wants to take a look Update your browser to use Google Drive - Google Drive Help
05-16-2019
pos trims are lean. but wot your also locked in to pe mode, the trims just locked in what ever they were just before you entered pe.
cant watch the scan now, its time to crash lol but you got the wb imported to the scanner as well?
![](http://i.imgur.com/In0Qnqi.jpg)
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
Turbo is the way to go.
05-16-2019
I'm all for whacking a table with fuel just to see if it does what I want.
So say you are still running positive trims of +10%. In this case I'd smack the whole MAF curve with 3% worth of fuel, reset the trims and see how much closer the trims get to 0%. My hunch is that you'll get down to around +4 to +6% give or take with the fuel added.
Once I know it's working, in most cases I use the wideband to find tune everything from there.
![](https://www.grandprixforums.com/image.php?u=8713&type=sigpic&dateline=1312942437&s=1fbdbe0fe05a0a834c299f8640c1f6ba)
GXP Level Member
05-17-2019
1.34 is about what you should set cylinder gain to.
GTP Level Member
05-19-2019
Do i need a wideband to run corn? My plan right now is to replace the fuel filter today, (the tank will almost be empty) fill up with e85 again, and then start dialing in the injector settings starting at 30. Then ill dial in the LTFT.
05-19-2019
set your injectors and leave them alone. tune the maf, and it dont matter if your stock or modded, if your tuning wot, you need a wb.
05-19-2019
you need a wideband to dial in your wot runs. if you set your injector duty cycle right then you won't need to mess with your maf, at least for adjusting for E85
