Thread: Swapped PCM leading to low LTFT and idk why!?
Results 1 to 16 of 16
  1. #1 Swapped PCM leading to low LTFT and idk why!?
    Oct 2018
    Tennessee
    Okay so I have a 2008 Grand Prix which, for some reason, isn't compatible with HP Tuners. To get around this I sapped out my 2008 PCU with one from a 2006 but even since I did the scanner is reading really low fuel trims when I'm at or near idle and I don't know why. I can't figure out for the life of me what is different between the 2006 and 2008 that would cause this??? Please help!
    Swapped PCM leading to low LTFT and idk why!? Attached Images
  2. #2 Re: Swapped PCM leading to low LTFT and idk why!?
    have you checked if your maf is the same part number as the year of the pcm? might just need the maf turned up.
  3. #3 Re: Swapped PCM leading to low LTFT and idk why!?
    Oct 2018
    Tennessee
    I think so but how can I check?
  4. #4 Re: Swapped PCM leading to low LTFT and idk why!?
    go to rock auto and search for a maf for your car and the donor pcm's car and see if the part # is different. if it is, thats the issue most likely.
  5. #5 Re: Swapped PCM leading to low LTFT and idk why!?
    Oct 2018
    Tennessee
    Yeah they're both the same
  6. #6 Re: Swapped PCM leading to low LTFT and idk why!?
    you can take some fuel from the maf. just a little bit in the lower areas, 1000-3000 is idle range, 3-7000 is cruise, 7 to the top is wot.
  7. #7 Re: Swapped PCM leading to low LTFT and idk why!?
    Have you compared the two bins for fueling and airflow? GM changed some stuff from year to year and if you look..likely you can find it and copy the table in.
  8. #8 Re: Swapped PCM leading to low LTFT and idk why!?
    2008 was a year only computer/calibration as they started the switch to can-bus, that is why it was never supported. Not worth their time to make a editable file for 1 year.
  9. #9 Re: Swapped PCM leading to low LTFT and idk why!?
    Oct 2018
    Tennessee
    What does that mean?
  10. #10 Re: Swapped PCM leading to low LTFT and idk why!?
    Oct 2018
    Tennessee
    That's what I was thinking but I don't know where to find a stock tune file for a 2008.
  11. #11 Re: Swapped PCM leading to low LTFT and idk why!?
    its time tp learn maf tuning
  12. #12 Re: Swapped PCM leading to low LTFT and idk why!?
    There are no 2008 V6 stock files, nobody ever created one.
    DHP and HPT never supported that year so nothing is available.
  13. #13 Re: Swapped PCM leading to low LTFT and idk why!?
    Kemmerer, Wyoming
    should have bought a GXP
  14. #14 Re: Swapped PCM leading to low LTFT and idk why!?
    Oct 2018
    Tennessee
    Okay I tried tuning the MAF table and it looks like that helped.
  15. #15 Re: Swapped PCM leading to low LTFT and idk why!?
    GT Level Member 97gtp01gt99gt's Avatar
    Sep 2018
    Saint Louis
    So do you tune pcm looking to get mines done or order one from zzp got p0171 running lean stft is about 20.3 and ltft 16.3 Ik those aren't right no leaks changed fuel filter no luck
  16. #16 Re: Swapped PCM leading to low LTFT and idk why!?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    Quote Originally Posted by 97gtp01gt99gt View Post
    with those lean trims, you probably have a vacuum leak. check again.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  1. Need a little help with ltft's
    By Rlugo87 in forum General Grand Prix Discussion
    Last Post: 09-10-2017, 10:36 AM
  2. Top swapped
    By Dragon1972 in forum PCM Tuning
    Last Post: 05-03-2012, 09:07 AM
  3. ltft?
    By jim97regalgs in forum PCM Tuning
    Last Post: 10-14-2011, 09:01 PM
  4. Swapped 05 L32 into an 04 L26 HELP???
    By lambokit in forum General Tech Discussion
    Last Post: 04-20-2011, 07:32 PM
  5. LTFT all over
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2009, 10:07 AM
