Thread: st5 cam
Results 1 to 8 of 8
  1. #1 st5 cam
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    Anyone have a bin file for turbo st5 cam? The fuel trims wont settle down, and I also cant get it to idle cold without holding the pedal for a few seconds. I'm using a north star t/b only bc its the only tb i have that can adapt to l26 intake. I adjusted the throttle screw ( as far as a could with maintaining 30-50 warm) but the iac still maxes out and cant maintain rpm, once the engine is warm the iac sets at 30ish like normal.
  2. #2 Re: st5 cam
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Did you use the IAC for the N* or use your Lwhatever IAC? They are different. If you didn't you'll either need to swap the pig tail connectors or get the zzp iac > N* adapter.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  3. #3 Re: st5 cam
    Jun 2013
    brookville,IN
    Yea its the right iac and harness. Im borrowing this tb and adapter from my fiero and it works fine for it.
  4. #4 Re: st5 cam
    Aug 2016
    MN
    Have you raised the idle at all? The st5 is a pretty big cam.
  5. #5 Re: st5 cam
    Jun 2013
    brookville,IN
    Yea its at 950-1000. Like i said before the iac maxes out but its not enof to keep it running at cold idle. I could try increasing the throttle plate screw, but iac is already sitting at 30 when warmed up.
  6. #6 Re: st5 cam
    Nov 2018
    Harrison, Ohio
    Hey neighbor,
    Have you had any luck with this? I am trying to help a friend with a st5 turbo build as well.
  7. #7 Re: st5 cam
    Jun 2013
    brookville,IN
    Hey, its coming along but not done tuning. Ill be putting the l67 tb back on tonight since I have an adapter now. This should fix the idle.
  8. #8 Re: st5 cam
    Jun 2013
    brookville,IN
    The tb swap fixed the issue
