Thread: New HPT MPVI 2 issues
Results 1 to 17 of 17
  1. #1 New HPT MPVI 2 issues
    Quincy, Mass
    So I was dumb and didn’t research before I bought the new hpt, still have my old one though it’s not for sale.
    Tried scanning for the first time with it today and noticed the knock retard doesn’t log. It shows up as supported but after I connect it disappears. Is this just a 4.0 software problem, anyone else having this issue? Am I limited to the amount of things I can log at once?
    Also having some trouble with the ltft + stft table logging, I know I had a similar problem with this in 3.6 so I’ll look into that a little more. But basically it won’t show up in all the boxes, just the first box.
    No more GP 04 Impala SS Indy:
  2. #2 Re: New HPT MPVI 2 issues
    The Boss Iceman6669's Avatar
    Jun 2011
    Im kinda HPT dumb so bare with me.... But do you mean logging as in the line graph on the bottom of the chart in the upper right hand side... Mine is v4.x.x and it shows up and records fine in the line graph on the bottom.
    2011 F-150 Yote powered
  3. #3 Re: New HPT MPVI 2 issues
    mine did this top row or top left corner bull sh it too. had to change the bottom line in property to bar. grams, kpa none of that crap would work right.
    knock retard has to be brought into the pid list on the left side pop out window. car must be running and plugged in and scanning to import those items.
  4. #4 Re: New HPT MPVI 2 issues
    FWIW, a lot of ppl on LS1tech and HP forums are having issues with HPT MPVI2 so you're not alone. a lot of angry threads were posted on the HP forums from what I read.
  5. #5 Re: New HPT MPVI 2 issues
    Since you have your old one.. why not grab a copy of the older software and use that until it gets sorted out?
  6. #6 Re: New HPT MPVI 2 issues
    Quincy, Mass
    Bill that’s what I plan to do for now.
    Car is running and connected. When I add knock retard it shows it is supported and adds it to the channels list. The when I hit record knock and a few others disappear from the list. Stop recording and it shows up again.
  7. #7 Re: New HPT MPVI 2 issues
    im running the latest version 4. what ever on the older standard wired type hpt. its all working fine.
    i bought a new lap top for tuning and had to copy all my crap over in the new scanner set up. saving the lay out and re using it on a new lap top dont save all the pid's in the list when you transfer over. or the maths for your wideband. had to re do all that manually.
  8. #8 Re: New HPT MPVI 2 issues
    Aug 2016
    MN
    I've been having problems with mine as well. I was messing around with it today and downloaded the beta version and tried that. It updated the firmware again and my problems seem to have gone away. It worked with the old stable release as well which seems to confirm my suspicion that it's in the unit not the software.
  9. #9 Re: New HPT MPVI 2 issues
    Quincy, Mass
    yes i saved all the config files and histograms. Everything works fine when i use 3.2, thats the last version i had downloaded, with my old wire. i dont think the new one will work with anything older than 4 but im going to give it shot. will try 4.0 with the old cable and see what happens too.
    anyone have a copy of 3.6 or whatever the last version was? is it in the dropbox?
  10. #10 Re: New HPT MPVI 2 issues
    Kemmerer, Wyoming
    I checked the dropbox and it has 2.2 in it. I think I have 3.6, but it's on my tuning computer. pm me your email and I'll email it to you when I get a chance
  11. #11 Re: New HPT MPVI 2 issues
    Quincy, Mass
    Thanks
    I tried the MPVI2 with 3.2 and it won’t recognize it. So I have 3.2 loaded for scanning and 4.1beta for editing.
  12. #12 Re: New HPT MPVI 2 issues
    Quincy, Mass
    mpvi2 doesnt work with 3.6 either
  13. #13 Re: New HPT MPVI 2 issues
    pretty sure you have to use 4.0 with the new interface. theres a new update out, its supposed to be less buggy, scanner works better im hearing on the fb group. its a firmware update.
  14. #14 Re: New HPT MPVI 2 issues
    Quincy, Mass
    I did the update before my last post, still have the same issue.
  15. #15 Re: New HPT MPVI 2 issues
    GT Level Member 40th GP's Avatar
    Utah
    Did this ever get resolved? I am looking for HPT but heard there were some issues. Is the new one good to go now?
  16. #16 Re: New HPT MPVI 2 issues
    It's pretty solid for the most part.
    I stuff I see people having issue with is when using it in the newest of new supported vehicles and vehicles that require a internet connection to read/write everything everytime.
  17. #17 Re: New HPT MPVI 2 issues
    Utah
    Cool, thanks! I think I will try to pick one up then.
  1. need help on two issues
    By paedbo in forum General Tech Discussion
    Last Post: 05-13-2014, 09:09 AM
  2. Abs issues?????
    By jewell83 in forum Brakes/Suspension/Chassis
    Last Post: 04-17-2014, 10:11 PM
  3. 20's..any issues?
    By bziggy58 in forum Tires & Wheels
    Last Post: 05-10-2012, 04:51 PM
  4. One man, many issues
    By Chief Runs With Coyotes in forum Introductions/Noob Questions
    Last Post: 05-06-2012, 08:11 PM
  5. TCS/ABS issues?
    By Iced Iridium in forum Brakes/Suspension/Chassis
    Last Post: 02-15-2012, 06:51 PM
