Thread: Trim relearn question
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Trim relearn question
    May 2008
    Schuyler, NE
    HP Tuners resets with the flash because it's flashing the whole file every time and I've never had an issue.
    Did they change this at some point on the newer versions? I think I'm running 3.6 and I still reset trims manually.
  2. #22 Re: Trim relearn question
    From what I remember my LTFT would be at zero after a flash. I think my newer truck is like that as well.
    Though depending on what I'm doing I hit reset set fuel trims anyway just to make double sure. So who knows, maybe I'm wrong lol.
    I believe a new flash also reset the knock learn factor as well but I don't think the 3800's use that feature.
  3. #23 Re: Trim relearn question
    Kemmerer, Wyoming
    I think on 3.6 if you just do a calibration it won't reset the trims.
  4. #24 Re: Trim relearn question
    May 2008
    Schuyler, NE
    I can't say I remember any version that reset fuel trims.
  5. #25 Re: Trim relearn question
    Yeah, maybe not a calibration only write.
    A write entire should reset everything though, but that is never required on a grand prix and only for VATS and OS changes on LS style computers.
  6. #26 Re: Trim relearn question
    May 2008
    Schuyler, NE
    Ah yeah. Entire writes do it. I can't actually think of a time I've done that with hpt though on a 3800.
  7. #27 Re: Trim relearn question
    May 2008
    Schuyler, NE
    Dhp didn't have that option in the beginning. You either had to write entire to reset trims, or disconnect the battery after a partial write to clear them. It was a huge deal when they added that option.
  1. interior dash trim question
    By hockeybawler in forum General Grand Prix Discussion
    Last Post: 07-20-2014, 10:11 AM
  2. tb relearn
    By dsmuts in forum 04+ Specifics
    Last Post: 02-28-2014, 10:21 AM
  3. post-carpet install 2004GTP TRIM question...
    By gloebird in forum General Tech Discussion
    Last Post: 07-15-2012, 07:49 PM
  4. No Relearn for Overkill PCM?
    By 04CompG in forum PCM Tuning
    Last Post: 09-14-2008, 07:12 PM
