Thread: Tuners in SOUTH JERSEY
Results 1 to 6 of 6
  1. #1 Tuners in SOUTH JERSEY
    Oct 2017
    South Jersey
    Hello, I am in need of a reputable tuner located in the area of south jersey. My gtp is having issues oscillating between third and fourth gear at a cruise and reads a vacuum leak when I cannot find one. The car is also very sluggish after shifts even at wot as the power drops off after a shift, then takes a couple seconds to get back into power. A fellow member brought to my attention that this could all be in the tune. Mods are l36 block, top swapped, 3.29 gears with non-hd, headers, cai, 1.9 rockers, and intense mail tune. Please let me know if anyone knows the causes of these problems and if there is anyone around south jersey that I can get in contact with that can take a look at the tune and correct it if need be. Thank you.
  2. #2 Re: Tuners in SOUTH JERSEY
    Mar 2017
    Internet
    If you top swapped.. you must have something in it for a tune to run it, what are you running and I'd suggest a trip up to middle/north jersey to Scottydoggs. He's also running a top swap and should be able to check/nail the issue.
  3. #3 Re: Tuners in SOUTH JERSEY
    im running the same tune i had before hand, just initially had to cut the timing.
    from the sound of his other thread they goofed and left the gtp gears in the file, where he needs a na ratio.
  4. #4 Re: Tuners in SOUTH JERSEY
    Oct 2017
    South Jersey
    Have an intense file on it right now. Contacted John rucker and he double checked the gear ratio and it's set to 3.29 with non hd diff like is suppose to. Don't know what now
    Sent from my SM-N920V using Tapatalk
  5. #5 Tuners in SOUTH JERSEY
    Quincy, Mass
    If the gear ratio is correct but the vss or reluctor setting, I forgot get what it’s called, is wrong then it won’t work right, feel like it’s slipping or delaying the shift. Or if the tcc is wrong too.
    Do you have a shift kit installed?
    No more GP 04 Impala SS Indy:
  6. #6 Re: Tuners in SOUTH JERSEY
    Oct 2017
    South Jersey
    Quote Originally Posted by Swiggles View Post
    Yes I have an intense street strip kit in
  1. hello from south jersey.....
    By HVACgtp in forum Introductions/Noob Questions
    Last Post: 10-30-2012, 06:27 AM
  2. Anyone else from South Jersey ?
    By corcor39 in forum Northeast
    Last Post: 02-16-2012, 01:34 PM
  3. New Guy from South Jersey
    By Grandprice700 in forum Introductions/Noob Questions
    Last Post: 09-21-2010, 12:14 AM
  4. south jersey?
    By mack1212 in forum Northeast
    Last Post: 05-25-2009, 12:05 AM
  5. New from south jersey
    By edp in forum Introductions/Noob Questions
    Last Post: 08-24-2008, 08:40 PM
