Thread: still cant get pe afr to move from 10.3
Results 1 to 5 of 5
  1. #1 still cant get pe afr to move from 10.3
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    I have tried adjustiing all afr settings in pe and it still keeps commanding 10.3. My actual and commanded are dead nuts but no matter what i do it keeps commanding 10.3 anyone know whats going on here?
  2. #2 Re: still cant get pe afr to move from 10.3
    have you messed with the maf settings?
  3. #3 Re: still cant get pe afr to move from 10.3
    Jun 2013
    brookville,IN
    Maybe im wrong but i assumed that since the commanded and actual is the same it would not be maf related? I did import a stock maf table to fix idle issues but that did not change the pe afr at all.
  4. #4 Re: still cant get pe afr to move from 10.3
    if you turn up the maf you can turn up the afr as well.
    what tuner you got?
    in pe, is it done by coolant temp? thats how it is in DHP.
  5. #5 Re: still cant get pe afr to move from 10.3
    Try remvoing the logged AFR channel, then re-poll for supported parameters and add the channel back into the channels list.
    If using HP Tuners.
    Aside from that make sure the add vs RPM is not adding to your commaned AFR. (hp tuners table.)
  1. Will move in 1 and 2 but not 3 or 4
    By MBruneaux in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-16-2014, 09:51 PM
  2. Should I fix my car or move on?
    By Bragill25 in forum General Grand Prix Discussion
    Last Post: 04-03-2013, 07:30 PM
  3. Car will not move in D or 3 but will in 2 or 1 need HELP!
    By LugNutLX in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-11-2011, 06:01 AM
  4. car won't move in D
    By Jayson in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-14-2010, 07:14 PM
