Thread: Having trouble tuning fuel trims cant be controlled by maf table
Results 1 to 19 of 19
  1. #1 Having trouble tuning fuel trims cant be controlled by maf table
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys having trouble getting the tune spot on and was just looking for some insight. Currently I can't really tune via the maf because its weird I could be at 2500hz one time and be -5 ltft and another time I could be at 2500hz and he at +5. So I noticed this problem mostly after switching to 60# injectors and so I'm thinking would the injector table being off cause this to happen. Cause my current maf table is only about 5% different from stock but yet in running 60# injectors on e54 and a bunch of other mods. So I'm thinking I over adjusted the fuel injector table which is now making it impossible to fine tune the fueling through the maf. Is this possible, thanks for your input guys
    Sent from my LG-H918 using Tapatalk
  2. #2 Re: Having trouble tuning fuel trims cant be controlled by maf table
    GTP Level Member buickman104's Avatar
    NYC
    What MAF and other mods are you running?
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: Having trouble tuning fuel trims cant be controlled by maf table
    iirc on corn you need to change the voltage pulse or something for the injectors.
  4. #4 Re: Having trouble tuning fuel trims cant be controlled by maf table
    Kemmerer, Wyoming
    I would check and make sure you have the correct injector flow rate. the IFR is a one time adjustment, set and forget. Like we said before, having a vacuum leak will skew all sorts of things. did you take the maf screen out of your throttle body? that will cause maf tuning issues too. another thing that can cause your maf to go rich then lean or vice versa is by making too many adjustments to fast, not an issue with the HP Tuner.
    for E85 all I did was change the cylinder gain from 1.00 to 1.3. for E54 I would try 1.15
  5. #5 Re: Having trouble tuning fuel trims cant be controlled by maf table
    Oct 2015
    Well what I think the problem is when I first tuned for my injectors rather then just changing ifr to reflect 60# injectors I did that but then added like 20% to the ifr table instead of the maf table to compensate for the e54. I'm asking if that's probably the reason why I'm getting wack readings because I basically f*cked up tuning the ifr table and then used the maf table to fix my mistake unknowingly.
  6. #6 Re: Having trouble tuning fuel trims cant be controlled by maf table
    Kemmerer, Wyoming
    not sure about that. does dhp have a cylinder gain table? maybe you should load a maf table from the last time it was good, then load the correct IFR and then adjust the cylinder gain to 1.15 or whatever.
  7. #7 Re: Having trouble tuning fuel trims cant be controlled by maf table
    you still got a breather on the valve cover? if so check back after you put a cap on.
  8. #8 Re: Having trouble tuning fuel trims cant be controlled by maf table
    Oct 2015
    I put the cap back on when I was trying to diagnose the other issue and it changed absolutely nothing I didn't even need to retune it at all. Like I said earlier this problem started a few months ago when I was trying to tune for the new injectors. Idk why everyone hates on the valve cover breather the car runs completely the same at most I might have lost .5hg of vacuum which makes 0 difference.
  9. #9 Re: Having trouble tuning fuel trims cant be controlled by maf table
    it does make a difference. your not supposed to run one unless your a turbo set up.
  10. #10 Re: Having trouble tuning fuel trims cant be controlled by maf table
    Oct 2015
    Ya but what's the alternative? Have oil shooting out my dipstick onto my headers or spending hundreds of dollars on a lim that has that stupid hole machined in it?
  11. #11 Re: Having trouble tuning fuel trims cant be controlled by maf table
    you have a zzp ic i take it? thers more then one way to skin a cat as they say..... http://www.grandprixforums.net/threa...cover-breather!
  12. #12 Re: Having trouble tuning fuel trims cant be controlled by maf table
    Oct 2015
    Ugh Scotty why you always trying to make me do things the right way instead of the easy way 😢
  13. #13 Re: Having trouble tuning fuel trims cant be controlled by maf table
    well doing it right should make your trims right. your letting un metered air in the engine
  14. #14 Re: Having trouble tuning fuel trims cant be controlled by maf table
    or if your ic has the pcv hole that dont match the hole in the lim, you can just drill a hole in the lim where its needed. iirc that info is within that link i posted.
  15. #15 Re: Having trouble tuning fuel trims cant be controlled by maf table
    Oct 2015
    Its the newest zzp one so I'm pretty sure it does have the hole but it wasn't as simple as just drilling a hole in the lim. You had to make a little recessed valley that went to a hole which is why I didn't do it because I didn't think I would be able to get the exact measurements correct just by looked at pictures. I know you can also put a nipple in the original oil cap or in the valve cover itself and run a vacuum line to it, but I forgot exactly where the vac line needs to come from. I believe it needs to be after the maf but before the butterfly.
  16. #16 Re: Having trouble tuning fuel trims cant be controlled by maf table
    how to run the line is in the how to there. if you got a tb spacer/adapter you can use that, or you drill and tap the brass button on the bottom of the tb.
  17. #17 Re: Having trouble tuning fuel trims cant be controlled by maf table
    Nov 2011
    NY
    Keep taking short cuts then wondering why things aren't working... I don't get it!
    again, I'll be a dick and point out that there are NO UNICORNS... It's all been done, results are proven, you want "this" then you'll ned to do "that" and you'll get it. Stray off the path, and there's no need to guess why it isn't doing what you want it to.
    just lol...
  18. #18 Re: Having trouble tuning fuel trims cant be controlled by maf table
    Quincy, Mass
    I know you don't want to hear but do the VE tune then retune the maf. I did the VE tune and it made it so much easier. Right now I still have to fine tune it as I'm running a bit rich at times. I'll have 0.0 at idle then at the next stop light it'll drop to -9 and then come back up to -3. I have to fine tune the VE because it's the same place on the maf all 3 times.
    No more GP 04 Impala SS Indy:
  19. #19 Re: Having trouble tuning fuel trims cant be controlled by maf table
    Oct 2015
    Quote Originally Posted by Swiggles View Post
    Ya I haven't done a ve tune yet so maybe I should mess with that
  1. Tuning my PE table for 3.4" pulley
    By 97AutoXVette in forum PCM Tuning
    Last Post: 04-09-2014, 09:43 AM
  2. getting fuel trims dialed in
    By Timing in forum PCM Tuning
    Last Post: 04-21-2013, 10:13 PM
  3. Fuel trims
    By zildjian102 in forum General Tech Discussion
    Last Post: 02-11-2011, 01:55 AM
  4. Help with fuel trims
    By 00gpgtp in forum PCM Tuning
    Last Post: 01-10-2009, 11:48 PM
  5. VE Tuning and Reseting Fuel Trims
    By JoshMcMadMac in forum PCM Tuning
    Last Post: 07-07-2008, 01:34 AM
