Thread: bcm question
Results 1 to 13 of 13
  1. #1 bcm question
    Nov 2012
    pistolvania
    just did a l67 swap and uploaded a dhp 1.5 to my pcm ....took it to the muffler shop to exhaust shop to weld 3 inch piping .....all of a sudden car doesn't start windows don't go down nothing to radio and port where you plug in dhp tuner inoperable also nothing to fuel pump....look under dash to bcm and 3 lines to bcm are cut and frayed ...my question is if i buy a new one it says has to be programmed to prevent drive ability issues...is this something dhp can do or am i screwed with dealer only....i am going to cross thread this in tuning as well
  2. #2 Re: bcm question
    DHP can do nothing with the BCM. That is something only a Tech 2 type scanner from a dealership will do.
    Why can't you just fix the wires going to the BCM?
  3. #3 Re: bcm question
    dhp cant do that.
    only a dealer can, and thats a maybe. fix the bad wires, see how it goes.
    check all your fuses too, the welder may have blown one.
  4. #4 Re: bcm question
    Nov 2012
    pistolvania
    checked fuses and fixed wires......but nothing inside is operable i have lights and chimes .even with key removed and door closed lights stay on had to unplug battery
  5. #5 Re: bcm question
    maybe the ignition harness took a crap.
  6. #6 Re: bcm question
    Nov 2012
    pistolvania
    would that give me all the other issues as well
  7. #7 Re: bcm question
    that harness can cause all sorts of issues, from no fan speeds but 5, parking lights not working, not starting, interior lights staying on.
    you try to jump the starter yet to see if it will run even?
  8. #8 Re: bcm question
    Nov 2012
    pistolvania
    it cranks over then shuts off after 1 sec ..i think cuz the fuel pump aint going
  9. #9 Re: bcm question
    that blows, somethings messed up for sure.
  10. #10 Re: bcm question
    Nov 2012
    pistolvania
    Anybody happen to have pictures where all the ground points are in the engine bay
  11. #11 Re: bcm question
    Donating Users moddman's Avatar
    Midwest
    Autel maxidas can do it.
    autelshop.com/wholesale/original-autel-maxidas-ds708.html?gclid=CK2S6pDa6csCFY-DaQodCdcPFg
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  12. #12 Re: bcm question
    Nov 2012
    pistolvania
    changed the rap relay and voila the car started all windows radio and such worked ...turned it off and now the fuel pump isnt going ....can anybody tell me how to do a case relearn with dhp i cant seem to find the option for live tools
  13. #13 Re: bcm question
    iirc it's in the scanner window. been a while since i did one.
    car has to be running to do one though.
  1. To mod, or to rebuild? That is the question.. The $2000 question
    By comatoast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 07:16 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
