Thread: Help tuning tcc using dhp! Flash kr problem.
Page 3 of 3 FirstFirst 123
Results 41 to 55 of 55
  1. #41 Re: Help tuning tcc using dhp! Flash kr problem.
    did your key span driver install the keyspan assistant? if you got that, it needs to to all be plugged in makes sure the speed in the assistant matches the speed on dhp too.
  2. #42 Re: Help tuning tcc using dhp! Flash kr problem.
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Keyspan assistant? I dont think so. Ive taken a few scans before usually if its shorter then a few minutes it will save but if i take a 5minute or longer scan it will stop saving right at the very end.
    Sent from my LG-D851 using Tapatalk
  3. #43 Re: Help tuning tcc using dhp! Flash kr problem.
    check your programs list, your on win 7 right? what i got, its on both my pc's. it tells you want comm port your plugged into and its speed, makes life easy instead of trying every listed # on dhp till you hit gold.
    ive tried both on high speed no dice for me, then tried it with one hi one low and it acted odd, made em both slow and bingo.
  4. #44 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    Nice ok its windows 8 but same thing im sure
  5. #45 Re: Help tuning tcc using dhp! Flash kr problem.
    only time i think i dint have the assistant was with XP. not sure about 8.
    ive ran dhp on XP vista, win 2000, and win 7. nothing newer.
  6. #46 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    Its amazing how much lighter the yella terras are
  7. #47 Re: Help tuning tcc using dhp! Flash kr problem.
    you get springs with them? time to raise the shift points, maybe that will make the tranny happy? never know right.
  8. #48 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    I have l76 springs already installed goodie. How high do you think i can raise them?
  9. #49 Re: Help tuning tcc using dhp! Flash kr problem.
    if you raise them to 5700 it will likely shift at 6000. you could go 6100-6200 but somethings gonna break like that. why push it to the moon?
    theres one line for shift rpm, another for mph. if your less then 75% throttle it will shift at the mph, if your 75% to wot it will shift per rpms. so you need to figure out what mph you shift at for the 6000 rpm's. then change that line if you want.
  10. #50 Re: Help tuning tcc using dhp! Flash kr problem.
    this is all in the trans folder of course
  11. #51 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    Cant i just change the shift rpm for wot? Also you have to remove the main belt tensioner to get the rear vc off right?
  12. #52 Re: Help tuning tcc using dhp! Flash kr problem.
    you can do it like that if you want, but if your not 100% throttle, it will shift early.
    the v/c, just back the 3 bolts off a little bit, the cover will be free to come off.
    take a look first, mines got a 1/4 inch gap. so its in the clear. 98 alt bracket, the one good thing about it.
  13. #53 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    Got rockers installed. Didnt take iy for a test drive yet but i did check start it. I got some smoke off the rear headers which i thought was just drips of oil from when i pulled the old pushrods out but then when i killed the motor i got a little hissing noise. So im going to double check the rear vc gasket tomorow just incase.
  14. #54 Re: Help tuning tcc using dhp! Flash kr problem.
    Kemmerer, Wyoming
    I ran 1.9 yt rockers on my last gtp with 105's and it really woke it up at higher rpm's. the hiss might be a bit of a vacuum leak, maybe the gasket didn't get set on there like it should have.
  15. #55 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    Thats what im thinking cause i just reused the gaskets that were on it since they were less than a month old after doing the swap but the rear gasket kept wanting to pop out. I should have used a couple dabs of rtv but i couldnt find it and was rushing haha
  1. Tuning trans question / Major WOT problem
    By Frosty in forum PCM Tuning
    Last Post: 10-09-2012, 04:49 PM
  2. EGR delete w/o PCM Flash
    By GP98GTX in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-02-2012, 06:09 AM
  3. Top Swap Re Flash problem
    By MNGP07 in forum PCM Tuning
    Last Post: 03-22-2009, 08:02 PM
  4. 3k stall problem, is it tuning related?
    By Biggie in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-07-2008, 06:29 PM
