Thread: Help tuning tcc using dhp! Flash kr problem.
Results 21 to 40 of 55
  1. #21 Re: Help tuning tcc using dhp! Flash kr problem.
    i get all that, but if this one is taking a crap, its needs another one. may as well get the hd tranny.
  2. #22 Re: Help tuning tcc using dhp! Flash kr problem.
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Well obviously i dont know how the previous owners drove the car but it does only have 95xxx miles that would suck if it was crapping out. I do know my pcs is bad idk if that would matter at all.
    Sent from my LG-D851 using Tapatalk
  3. #23 Re: Help tuning tcc using dhp! Flash kr problem.
    is that a tranny pressure control solenoid?
  4. #24 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    On a side note when i first got the car i changed the tranny fluid and it was in good looking shape nothing out of the ordinary. I also think my axles might be acting up its pretty rare but occasionally when im breaking and turning at the same time theres like a little pop/cracking noise i can feel
  5. #25 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    Yes the pressure control solenoid. A month after i got the car i started getting really hard shifts which is when i installed the shift kit and that took care of that.
  6. #26 Re: Help tuning tcc using dhp! Flash kr problem.
    so you had the max adapt code then?
    maybe upping the line pressure some may help then. it maybe bleeding off pressure at the shift or something like that. im no tranny expert tho.
  7. #27 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    I dont recall ever getting a code for it. I know currently line pressure is slightly increased over stock but idk how much i can increase it.
  8. #28 Re: Help tuning tcc using dhp! Flash kr problem.
    are you able to get a hold of race fuel? if so, pour a couple gallons of that in the tank when near 1/4 low and do another scan. if race fuel isnt locally available go to any place that sells paint (shermin williams, ace hardware, lowees etc) and pick up a gallon can of tuluene or xylene and mix with about 5-6 gallons of 92/93 oct.
    http://www.rx7club.com/rotary-car-pe...e-fuel-669583/
    http://www.supraforums.com/forum/sho...ene-experience
    this is just to ensure its real KR or not. if the KR spike still comes up, then you know it's false.
  9. #29 Re: Help tuning tcc using dhp! Flash kr problem.
    he could take the sc belt off for free. drive it hard see if it knocks at the shifts still.
  10. #30 Re: Help tuning tcc using dhp! Flash kr problem.
    ^true, but i dunno if it'll have enough of the torque/power to cause any false KR. i mean it is only 8.5:1 CR and being on 2.93 (im assuming) would be a slow ass boat lol. then again he could unplug the BBV and limit to running 4psi and go from there.
  11. #31 Re: Help tuning tcc using dhp! Flash kr problem.
    hes top swapped with a na tranny. he could take the sc belt off, pop in na timing and have at it he really wanted too. lucky hes got a tuner now.
  12. #32 Re: Help tuning tcc using dhp! Flash kr problem.
    ^gotcha on he's topswapped.
  13. #33 Re: Help tuning tcc using dhp! Flash kr problem.
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    I get about 1-3 degrees of KR too when I down shift hard. I also see a few blips of KR in the same gear but at 20% throttle. Haven't figured that out yet though.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  14. #34 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    So take sc belt off?
  15. #35 Re: Help tuning tcc using dhp! Flash kr problem.
    remove belt, do the same thing that makes it spike. if it still spikes its the tranny for sure causing it.
  16. #36 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    Ok so i just went for a quick drive. I have not taken the belt off yet. I tried taking a scan using dhp, of course it didnt want to save.. The good news is on was on torque pro and today it was seeing on average .5-1* of kr on 4-2 and 3-1 downshifts which is odd because its always been way higher. The only thing i have changed recently in my tune is i finally got my fuel trims tuned better and now they lock in within 1%. I dont know if this could have any effect on my problem or maybe my issue is just intermittent.
  17. #37 Re: Help tuning tcc using dhp! Flash kr problem.
    thats a blips worth and just fine. its all i ever see for kr.
    go over your dhp speeds and stuff, maybe somethings not calibrated right.
  18. #38 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    The only thing i didnt know what to put was when i registered it it asks for some kind of speed and i just picked the higher number lol
  19. #39 Re: Help tuning tcc using dhp! Flash kr problem.
    make it the slower speed, i bet it works better.
    you got a older dhp with a keyspan right? lok in options to change the speed too. i got pics some where if you need em.
  20. #40 Re: Help tuning tcc using dhp! Flash kr problem.
    Oct 2015
    Ok sounds good ill give you an update in a while when i go back out again. Thanks
  1. Tuning trans question / Major WOT problem
    By Frosty in forum PCM Tuning
    Last Post: 10-09-2012, 04:49 PM
  2. EGR delete w/o PCM Flash
    By GP98GTX in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-02-2012, 06:09 AM
  3. Top Swap Re Flash problem
    By MNGP07 in forum PCM Tuning
    Last Post: 03-22-2009, 08:02 PM
  4. 3k stall problem, is it tuning related?
    By Biggie in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-07-2008, 06:29 PM
