Thread: monitoring the wheel speed sensor with hp tuner
Results 1 to 5 of 5
  1. #1 monitoring the wheel speed sensor with hp tuner
    Kemmerer, Wyoming
    is there a way to monitor the wheel speed sensor with an hp tuner
  2. #2 Re: monitoring the wheel speed sensor with hp tuner
    No, they can not read ABS functions.
    Only VSS on trasnmissions or transfer cases.
    If you had a MS3 gold box, you could wire in an external hall effect sensor to read the wheel speed of the lug studs or something similar.
  3. #3 Re: monitoring the wheel speed sensor with hp tuner
    T app can
  4. #4 Re: monitoring the wheel speed sensor with hp tuner
    Kemmerer, Wyoming
    T app can
    I'm going to have to start using that app
  5. #5 Re: monitoring the wheel speed sensor with hp tuner
    you need the add on torque scan, its free. or i just i found it after i installed that add on.
  1. 07 speed sensor wheel bearing issue.
    By Mirraco in forum General Grand Prix Discussion
    Last Post: 05-02-2015, 11:13 PM
  2. wheel speed sensor issues
    By jhintz in forum General Grand Prix Discussion
    Last Post: 05-19-2014, 05:26 PM
  3. Wheel Speed Sensor
    By blackthunder in forum General Tech Discussion
    Last Post: 02-26-2014, 12:05 AM
  4. Wheel speed sensor
    By GXPrunner06 in forum General Tech Discussion
    Last Post: 03-22-2013, 10:30 AM
  5. Wheel Speed Sensor Wireing harness
    By packerfanjc in forum Tires & Wheels
    Last Post: 02-16-2011, 10:09 AM
