Thread: Anyone in the Northern VA area? I need some codes removed
Results 1 to 16 of 16
  1. #1 Anyone in the Northern VA area? I need some codes removed
    Aug 2013
    Virginia Beach, VA
    Hello, I live in Virginia Beach but would be willing to drive anywhere within a ~50 miles radius. I need a P0420 code removed and codes associated with my secondary air injection system as I am removing it and installing ZZP front and rear powerlogs and ZZP downpipe. I need to reregister my car January 1st and I need to get this done before then. Price negotiable. Thanks in advance!
  2. #2 Re: Anyone in the Northern VA area? I need some codes removed
    if you cant find a local you can ship your pcm to me and i can take care of them codes.
  3. #3 Re: Anyone in the Northern VA area? I need some codes removed
    Aug 2013
    Virginia Beach, VA
    I would if this wasn't my daily driver. I can't really afford any downtime. What area do you live in? I wouldn't mind making this a day trip as it's something I need to get done. Police down here are pretty rough. Last year I received a $142 fine for tags that were expired by 1 day. So I can't afford to run that risk again.
  4. #4 Re: Anyone in the Northern VA area? I need some codes removed
    im in NJ 10 miles form the GWB. about 2 -3 hr trip up the tpk from the del border i think. if you still have your stock pcm you can run that just dont go beating on it.
  5. #5 Re: Anyone in the Northern VA area? I need some codes removed
    Aug 2013
    Virginia Beach, VA
    This is my stock PCM. I'm actually going up to Dover, DE on Dec 29-31. How far are you from there? And would you be free on one of those days?
  6. #6 Re: Anyone in the Northern VA area? I need some codes removed
    oh, i saw zzp and thought tune lol
    from dover its about the same. im sure i could find time during those dates. it dont take long maybe 15 minutes in all.
  7. #7 Re: Anyone in the Northern VA area? I need some codes removed
    Aug 2013
    Virginia Beach, VA
    I'd really appreciate it!
  8. #8 Re: Anyone in the Northern VA area? I need some codes removed
    send me a pm when your ready to shoot up.
  9. #9 Re: Anyone in the Northern VA area? I need some codes removed
    Aug 2013
    Virginia Beach, VA
    Will do! Thanks man
  10. #10 Re: Anyone in the Northern VA area? I need some codes removed
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    Im in Waldorf MD. If youre taking the 301 route, you will pass by as close as 5 miles from my home. PM me...
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  11. #11 Re: Anyone in the Northern VA area? I need some codes removed
    that sounds better then a trip to north NJ to me lol
  12. #12 Re: Anyone in the Northern VA area? I need some codes removed
    Apr 2013
    Waldorf MD
    Lol. Just trying to help. That's all. He can stop by as he is passing thru. Unless he takes 95 north straight thru. I'm not far from 95 either. I can catch him passing thru on the MD side of 95. I'm 30 minutes away...
  13. #13 Re: Anyone in the Northern VA area? I need some codes removed
    Apr 2013
    Waldorf MD
    Did you get this resolved?
  14. #14 Re: Anyone in the Northern VA area? I need some codes removed
    i never heard from him.
  15. #15 Re: Anyone in the Northern VA area? I need some codes removed
    Apr 2013
    Waldorf MD
    Neither have I...
  16. #16 Re: Anyone in the Northern VA area? I need some codes removed
    Aug 2013
    Virginia Beach, VA
    Quote Originally Posted by jaydubb71 View Post
    Neither have I...
    Hey guys, sorry for the late response! The past couple weeks have been a little crazy. The good is that I was able to renew registration without requiring inspection. So I just did that, I also did a full top end/exhaust rebuild with ported heads, ported LIM, LS7 lifters, ARP studs, Yella Terra 1.84 roller rockers, HV3 insert, front and rear ZZP power logs, and ZZP cat'd downpipe, so the light is off!
  1. Need A Exhaust System For CompG (Northern Ohio or Toronto Area)
    By ExpertAdviceMan in forum Wanted To Buy - Parts
    Last Post: 03-23-2015, 07:51 PM
  2. Replies: 11
    Last Post: 03-08-2012, 12:09 AM
  3. Replies: 1
    Last Post: 03-02-2012, 08:56 PM
  4. **NORTHERN IL AREA** SLP Pulley Tool
    By tropicalrays76 in forum Midwest
    Last Post: 02-22-2012, 04:09 PM
  5. Replies: 0
    Last Post: 07-06-2010, 08:18 PM
