Thread: AC compressor runs in heat modes on HVAC
Results 1 to 20 of 32
  1. #1 AC compressor runs in heat modes on HVAC
    Mar 2015
    USA
    Is it normal for the AC compressor to run whenever the HVAC controls are set on anything floor related? (Car is a 04 Impala FWIW)
    I'm not crazy about having my AC compressor running all winter long so I thought about bumping up the min IAT to enable AC and see what happens.
    -'04 Impala SS - 3.6 pulley, AL 104s, ZZP DP, PLOG, 180stat, 1.9 rockers, gutted airbox mod, basic tune
  2. #2 Re: AC compressor runs in heat modes on HVAC
    normal. pull the ac relay out of the fuse box if you want it to not run.
  3. #3 Re: AC compressor runs in heat modes on HVAC
    hangover park IL
    but then be ready for your defrost functions to not work as well. the air conditioning runs to pull the moisture out of the warm air that is trying to defog your windows. you can guess how much harder it is to defog your windows when the AC is not condensing moisture out of the air
    ~James~ Psychotic Gearhead
  4. #4 Re: AC compressor runs in heat modes on HVAC
    ive ran with the relay out and in, defroster works just fine either way.
    but that is why it runs, to help draw moisture out of the air.
  5. #5 Re: AC compressor runs in heat modes on HVAC
    Mar 2015
    USA
    Quote Originally Posted by Turbocharged400sbc View Post
    That's what I figured. I'm fine with it running on defrost, just have never seen a car that runs it on heat (floor). I notice with it blended between floor and vent it doesn't run. I'll try the relay. Worst case I have to put it back in.
  6. #6 Re: AC compressor runs in heat modes on HVAC
    Buffalo
    Why does it bother you?
  7. #7 Re: AC compressor runs in heat modes on HVAC
    Jan 2014
    AR
    Its also made that way to reduce problems with the A/C system that can arise from non-use during an entire winter.
  8. #8 Re: AC compressor runs in heat modes on HVAC
    SWPA
    People say that all the time yet myself as well as many others have noticed no difference with ac to no ac defrost capabilities. If you ask me, from my experience no ac defrost works better than ac defrost.
  9. #9 Re: AC compressor runs in heat modes on HVAC
    Jan 2014
    AR
    Oh, theres a difference.... the conditioned air clears fog much faster before the heater core is hot. But defrost without A/C does work well enough, especially in mild climates.
  10. #10 Re: AC compressor runs in heat modes on HVAC
    Buffalo
    Defrost and defog. De frost it won't do much. But when it's fogged up like when it rains out - makes a huge difference.
  11. #11 Re: AC compressor runs in heat modes on HVAC
    Mar 2015
    USA
    Quote Originally Posted by CrazyGuy03 View Post
    Because I'm mildly OCD and somehow think it's going to save me a fraction of a mpg, and less wear on the compressor.
  12. #12 Re: AC compressor runs in heat modes on HVAC
    So it's something thats been a feature for 11 years on the car and is now a concern??
    I mean every single car does this and nobody bats an eye at it.
    But it's your car I guess, just seems pointless.
  13. #13 Re: AC compressor runs in heat modes on HVAC
    Jan 2014
    AR
    Too bad its not a 99 GP, all you have to do is press the A/C button after startup and it behaves normally but without running the compressor.
  14. #14 Re: AC compressor runs in heat modes on HVAC
    Buffalo
    In the regal just hit "vent" I think
  15. #15 Re: AC compressor runs in heat modes on HVAC
    what about all the cars out there that came with no ac at all? or no working ac in all the cars out there,,,,those guys dont seem to complain about the defroster not working ever, do they?
  16. #16 Re: AC compressor runs in heat modes on HVAC
    Jan 2014
    AR
    Quote Originally Posted by ScottyDoggs View Post
    That was me, 1980-2009. No choke either half the time. In the south it might be different, so web tales may vary.
    GPs don't run the compressor when its below 37 degrees out. Most cars have an easy way to turn it off on the dash. Pulling the relay would remove that daily step though.
  17. #17 Re: AC compressor runs in heat modes on HVAC
    I had no A/C for nearly 5 years of owning my grand prix, winter did suck ass when it came to getting my windshield clear right away sometimes. I always had to wait extra long to be able to see.
    I'd rather have it working.
  18. #18 Re: AC compressor runs in heat modes on HVAC
    Buffalo
    Yeah. That's what I said earlier. The heat will DEFROST yer window. The AC helps DEFOG the window
  19. #19 Re: AC compressor runs in heat modes on HVAC
    GXP Level Member
    Mar 2015
    Tomball
    We have the opposite problem down here in summer. When it's hot and humid and raining it is nearly impossible to clear a fogged up windshield without having the compressor run. On a side note can't the OP just putt the AC in the off position and use those without the compressor running?
    Jeff
  20. #20 Re: AC compressor runs in heat modes on HVAC
    nope. the damn thing runs if the heat is on only.
  1. Radiator fan runs all the time = NO HEAT!
    By cr4ck3r in forum Introductions/Noob Questions
    Last Post: 01-03-2014, 07:34 PM
  2. HVAC Issue. Cant switch between any of the vents for heat
    By JohnnyV in forum General Tech Discussion
    Last Post: 12-27-2013, 06:58 PM
  3. HVAC modes not working, help me decifer these codes please.
    By jdmgtp in forum General Tech Discussion
    Last Post: 02-11-2013, 07:37 PM
  4. ac compressor kicks on when I turn on the heat
    By Silversurfer Gio in forum General Tech Discussion
    Last Post: 01-02-2012, 05:52 PM
  5. Low Air Flow on Heat HVAC
    By scootcoupe91 in forum General Tech Discussion
    Last Post: 12-12-2009, 06:41 PM
