Thread: KR Issue
Results 1 to 11 of 11
  1. #1 KR Issue
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Ive been having a bit of a KR issue lately ie max of 4* around 80% throttle.
    Mods:
    3.4 Pulley
    9.4 to 1 compression
    XP Cam
    3" DP
    ZZP 3" Exhaust
    Intake
    AL 104 plugs @ .050
    Pump 93 octane
    I have not installed the headers yet, but i planned on doing that Monday
    Im thinking that i dont have enough exhaust flow for a 3.4 but i need to be sure.
    Any suggestions?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: KR Issue
    install headers, check back after that.
  3. #3 Re: KR Issue
    needs headers
  4. #4 Re: KR Issue
    Sep 2015
    flint
    headers are the worst possible mod you can do on a 3800.
    What AFR/timing are you having problems with? High compression stuff might want to see 13-14 degrees on a setup like this.
    Doesnt run 9s
  5. #5 Re: KR Issue
    Apr 2014
    South Haven, MI
    Quote Originally Posted by notdarkhorizon View Post
    First, Why are headers terrible?
    Second, My solution was to use eddies table modifier to lower timing as a band-aid until i can get the exhaust flowing more.
  6. #6 Re: KR Issue
    Sep 2015
    flint
    Its not wrong to run a little less timing. headers are not going to "help get the exhaust flowing more" on a setup like that.
    Doesnt run 9s
  7. #7 Re: KR Issue
    Apr 2014
    South Haven, MI
    You keep saying that but not explaining.
    Im on stock manifolds with a 3" DP.
  8. #8 Re: KR Issue
    Apr 2014
    South Haven, MI
    Im now KR free after the header install.
  9. #9 Re: KR Issue
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    Quote Originally Posted by BoostedPontiac View Post
    But..but..but..they're the worst possible mod.
  10. #10 Re: KR Issue
    hangover park IL
    the factory manifolds and old factory mufflers are the worst for flow.
    lost 2 psi of boost from ditching the factory mufflers and exhaust. on some cars i could see it being worse since the baffle holes rust and close up before the baffles rot away....
    good luck having muffs that the baffles have rotted through yet the muffler case hasnt lol
    the borla exhaust sounds great but its a helluva restriction...i have back to back dyno tests that show the boost drop and going lean as hell from a beautifully tuned setup with the exhaust connected, to a 18" 3" straight pipe.
    317 at the wheels with a stock cam build
    ~James~ Psychotic Gearhead
  11. #11 Re: KR Issue
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    Headers are the worst mod? Maybe I need to put my stock manifolds back on my G8 and my GTP. I will miss the added noise and speed tho. LOL
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  1. Weird speedometer issue, possible trans issue?
    By Peder in forum General Tech Discussion
    Last Post: 07-28-2014, 07:08 PM
  2. Issue with A/C no more cold air and sound issue with Shocks
    By ibra0078 in forum General Grand Prix Discussion
    Last Post: 08-09-2013, 08:25 AM
  3. Wheel Bearing Issue or Tire Issue
    By ibra0078 in forum Tires & Wheels
    Last Post: 06-07-2013, 05:12 AM
  4. HID issue
    By Adasm in forum Audio, Security & Visual Electronics
    Last Post: 12-07-2012, 10:03 PM
  5. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
