Thread: Anyone know where this plug goes?
Results 1 to 20 of 35
  1. #1 Anyone know where this plug goes?
    Sep 2014
    chicago
    Found this plug tucked behind the windshield washer reservoir. Anyone know where it goes?
  2. #2 Re: Anyone know where this plug goes?
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    Does your windshield washer work? If not it goes to the fluid pump.
  3. #3 Re: Anyone know where this plug goes?
    goes to nothing is my guess. we all got at least one plug that goes no where under the hood.
  4. #4 Re: Anyone know where this plug goes?
    SWPA
    Flux capacitor.
  5. #5 Re: Anyone know where this plug goes?
    Sep 2014
    chicago
    Yes the washer works. I was thinking maybe it goes somewhere below the engine. Idk.... I don't want to say forget it as the car is not running to its full potential. Guess I'll have to tear into the engine.
  6. #6 Re: Anyone know where this plug goes?
    if it was unplugged form somewhere it would have set the cel.
    if your cel is on, get it scanned for codes. tearing into the engine is not the fix yet.
  7. #7 Re: Anyone know where this plug goes?
    May 2012
    Where winter never ends
    What he said. Check for codes... if there is a **** Circuit low or ***** Circuit high or something like that .. .you found your problem
    2000 Regal - Winter Beater
  8. #8 Re: Anyone know where this plug goes?
    What year and model?
  9. #9 Re: Anyone know where this plug goes?
    Sep 2014
    chicago
    Nope no codes only p0442 which I have to change my rusty fuel and evap lines
  10. #10 Re: Anyone know where this plug goes?
    Sep 2014
    chicago
    2000 Buick PA Ultra
  11. #11 Re: Anyone know where this plug goes?
    so whats not up to its potential? whats it doing? we cant read minds yet lol
  12. #12 Re: Anyone know where this plug goes?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Not necesarily all unplugged things will set a CEL, I deleted my airpump in my 00 Bonneville, just unplugged it, no codes every showed up. Come to think of it... that plug looks similar.
    04 GTP -HAI, 1.9 rockers.
  13. #13 Re: Anyone know where this plug goes?
    Sep 2014
    chicago
    Its lacking power and slightly rough idle. I remember changing the plugs and didn't feel any restored power at all. Plus my mpgs are low I'm getting 15 mpg city and highway. I checked fuel pressure its 42 key on. When I prime it, it shows 48 then goes down a couple psi. When I start it and remove the hose to the for it jumps to 50 psi
  14. #14 Re: Anyone know where this plug goes?
    Sep 2014
    chicago
    I've just disconnected my air pump from the rear since it never worked and installing the ak29 adapter so I can manually put air into my struts.
  15. #15 Re: Anyone know where this plug goes?
    what plugs you use?
  16. #16 Re: Anyone know where this plug goes?
    Aug 2013
    Sandy, UT
    Quote Originally Posted by ayeb View Post
    .............Different air pump. Lol
  17. #17 Re: Anyone know where this plug goes?
    Sep 2014
    chicago
    what plugs you use?
    Delcos
  18. #18 Re: Anyone know where this plug goes?
    Sep 2014
    chicago
    Quote Originally Posted by SnowTh1ef View Post
    What's the other air pump for
  19. #19 Re: Anyone know where this plug goes?
    Aug 2013
    Sandy, UT
    Pumps air into the rear exhaust manifold to make the cat more efficient and help emissions overall.
  20. #20 Re: Anyone know where this plug goes?
    Delcos
    delco whats?
  1. Plug?
    By mintygp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-05-2013, 08:41 AM
  2. 2008 Base model plug and plug wire swap
    By MS1227 in forum 04+ Specifics
    Last Post: 12-06-2012, 06:14 PM
  3. stock antenna plug to universal plug?
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2012, 10:25 PM
  4. plug gap
    By NoTyme in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-16-2009, 06:11 PM
  5. PLUG??
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2009, 04:47 PM
