Thread: 2005 Chevy Cavalier 2.2 Ecotec
Results 1 to 16 of 16
  1. #1 2005 Chevy Cavalier 2.2 Ecotec
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    Hey guys I am in need of direction. This weekend I worked on a 05 Cavalier with fuel issues. I checked pump relay it was working and concluded the pump was not kicking on. Dropped the tank and replaced with a Delphi Unit. Also changed the fuel filter. The old filter was full of black sh*t . It was by far the nastiest fuel filter I have ever seen. Nothing but black slime coming out. Assuming the bad filter caused the pump to fail. On initial fire up car ran a bit rough and finally idled fine for a small amount of time. At this point I threw in a can of sea foam after seeing that filter. Who knows if that filter was stopping anything. The car is now misfiring horribly and has severe lifter chatter. Checked the oil it was significantly low added appropriately and still chattering. I pulled the codes and came up with P0300 - Random Cylinder Misfire and P0171 - System to lean - Bank 1 . Now I would assume the lean condition is from gummed up or clogged fuel lines or possibly just bad gas. So I started by pulling each plug individually all looked good - were just replaced 3 months ago. They smelled extremely of gasoline and seemed to be wet with gas as well. I suppose the a faulty ignition coil could cause this but what are the odds of this happening at the same time as a fp. Probably slim to none. Just in need of some help and to see what other may or may not have experienced with this vehicle
    Thanks
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  2. #2 Re: 2005 Chevy Cavalier 2.2 Ecotec
    Mar 2012
    NC
    ICM's on those go bad randomly...so don't be surprised if that's the issue.
  3. #3 Re: 2005 Chevy Cavalier 2.2 Ecotec
    Pin it to the floor, it may clear up..
  4. #4 Re: 2005 Chevy Cavalier 2.2 Ecotec
    Nov 2013
    Des Moines, IA
    Why the lifter noise. Its no normal sound. Its BAD I will make a video later and show you.
    2007GPGTSC
    " sad thing is "
  5. #5 Re: 2005 Chevy Cavalier 2.2 Ecotec
    I wish I knew more, hard to comment over the net without the vehicle in front of me.
    I know the ecotech's can get louder over time, like when an oil change is done and you start they like to clatter alot but it's gone in 2-3 seconds.
    But like sven said the 1 piece ICM is a common problem, that could be the misfire problem.
  6. #6 Re: 2005 Chevy Cavalier 2.2 Ecotec
    Nov 2013
    Des Moines, IA
    I will throw up a video so you guys can get an idea
    2007GPGTSC
    " sad thing is "
  7. #7 Re: 2005 Chevy Cavalier 2.2 Ecotec
    Nov 2013
    Des Moines, IA
    2007GPGTSC
    " sad thing is "
  8. #8 Re: 2005 Chevy Cavalier 2.2 Ecotec
    Jesus, sounds terrible lol.
    Motor has oil right???
    Might be time to remove the valve cover and see if anything is broken.
  9. #9 Re: 2005 Chevy Cavalier 2.2 Ecotec
    Nov 2013
    Des Moines, IA
    I already did cranked it nothing looked out of the ordinary I did find what looked to be a piece of broken plastic it was orange not sure how the hell it got in there. But it has gradually gotten worse. Yesterday it was not this bad. I added 2quarts of 10w 30 because I figured what the hell little thicker won't hurt. And no change at all. It doesn't really sound like rod knock not sure what it is
    2007GPGTSC
    " sad thing is "
  10. #10 Re: 2005 Chevy Cavalier 2.2 Ecotec
    Nov 2013
    Des Moines, IA
    Timing chain looked good from what I can tell all looked to be oiled well ect.
    2007GPGTSC
    " sad thing is "
  11. #11 Re: 2005 Chevy Cavalier 2.2 Ecotec
    Nov 2013
    Des Moines, IA
    Sounds like it should be called the ecotec tdi hahaha
    2007GPGTSC
    " sad thing is "
  12. #12 Re: 2005 Chevy Cavalier 2.2 Ecotec
    I wonder if the timing chain tensioner/guide has broken.
  13. #13 Re: 2005 Chevy Cavalier 2.2 Ecotec
    Nov 2013
    Des Moines, IA
    Would it cause a terrible knock like that?
    2007GPGTSC
    " sad thing is "
  14. #14 Re: 2005 Chevy Cavalier 2.2 Ecotec
    Well, you have a horrible misfire plus engine noise and likely some pinging going on.
    So it's hard to say exactly what is casuing the noise. It doesnt sound lower end though which is good.
  15. #15 Re: 2005 Chevy Cavalier 2.2 Ecotec
    Nov 2013
    Des Moines, IA
    I am going to assume it's the timing chain tensioner or the balancer simply because of this https://www.youtube.com/watch?v=M0WRDlk7Ew4&app=desktop
    2007GPGTSC
    " sad thing is "
  16. #16 Re: 2005 Chevy Cavalier 2.2 Ecotec
    Nov 2013
    Des Moines, IA
    The misfire is solved BTW replaced with a junkyard icm and coilpack for 30 bucks no more misfire
    2007GPGTSC
    " sad thing is "
  1. 2.2 ecotec rod knock
    By vandezand in forum Off Topic Discussion
    Last Post: 09-09-2013, 02:24 PM
