Thread: l67 camaro
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 110
  1. #81 Re: l67 camaro
    May 2012
    Where winter never ends
    stupid. modify the blower
    2000 Regal - Winter Beater
  2. #82 Re: l67 camaro
    Aug 2013
    tallahassee
    Can you use a 2 bar map from a stock l67 car on a n/a car or will it not work with the pcm?
  3. #83 Re: l67 camaro
    May 2012
    I think you can use a 2bar. dont quote me.
  4. #84 Re: l67 camaro
    Aug 2013
    tallahassee
    I understand it may be more work, but I'm going to modify the firewall.
  5. #85 Re: l67 camaro
    Why..
    Wht makes you want to modify the firewall more then the blower. Is it because of the pretty paint?
    04 Comp G.
  6. #86 Re: l67 camaro
    Aug 2013
    tallahassee
    Availability and price of tig welding aluminum where I'm at. This has been a budget build, and molding the firewall will be quite easy with the engine out, I will cut out a section, and bolt in a recessed plate for clearance. If I lose my defrost controls I'm not going good to sweat it. Just seems like an easier option, my buddy is going to weld a Stainless elbow for me and thermostat housing.
  7. #87 Re: l67 camaro
    May 2012
    Snow did it without any welding.... cut the blower, drilled tapped holes, silicone, some random 3in flat plate fittting and boom. Done. Talk to him and for the love of god dont cut the firewall. That is sheer stupidity.
  8. #88 Re: l67 camaro
    Yea I was going to say I don't think Snow did any of that.
    04 Comp G.
  9. #89 Re: l67 camaro
    Jan 2009
    Tallahassee, FL
    Don't hack up the firewall. Just save up the extra couple of hundred to get it done right.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  10. #90 Re: l67 camaro
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    My cost of modifying the blower the right way with all the pipe couplers tap bolts silicone everything was under 100$. Zero aluminum tig welding.
    04 GTP -HAI, 1.9 rockers.
  11. #91 Re: l67 camaro
    Never Never Land
    If you talk to Dave at TEP he might mod you a blower. I emailed him awhile back and he was willing to do it.
  12. #92 Re: l67 camaro
    Aug 2013
    tallahassee
    GUYS! I do appreciate the input, but on this aspect of the build I will not be modding the blower case. Lol. If it does so happen that this doesn't work out I will for sure try to contact someone who can modify it. Then yall can say I told you so right now I'm still trying to teach myself tuning with dhp, that seems like the most complicated part of this build. Here's to hoping that 2 bar map will work, and that I can use the stock maf sensor.
  13. #93 Re: l67 camaro
    Aug 2013
    tallahassee
    BTW the bottom end is from a low mileage l26. What do yall recommend with a pulley size? I'll be running an aem progressive methanol kit along with the other mods.
  14. #94 Re: l67 camaro
    Banned
    CT
    Neat setup man but you may have ruined that m90 case trying to port it.
  15. #95 Re: l67 camaro
    Feb 2009
    flintnasty MI
    Quote Originally Posted by kylecamarors38 View Post
    Can I use a 2 bar map sensor from a l67 with my setup for tuning? Or will it not read correctly with my pcm? I hear tuning with the 1 bar map can be quite difficult
    Why would it matter? Map sensors are not used for fueling in any form.
  16. #96 Re: l67 camaro
    Aug 2013
    Sandy, UT
    Just leave the 1 bar.
  17. #97 Re: l67 camaro
    It's not going to work without hacking half of the TB side of the blower case off.
    You might as well put the stock intake manifold on and turbo it.
    Would be cheaper, and the car would be faster.
  18. #98 Re: l67 camaro
    May 2012
    This is gonna be funnnnnny to watch. Map sensor doesnt matter so who gives a ____. Hack the blower off and do it right not the way your crazyness is set on.
  19. #99 Re: l67 camaro
    Feb 2009
    flintnasty MI
    Tuning a l36 car for boost requires changing 2 tables and adjusting the injectors for whatever injectors you install. If it takes more than 20 minutes to get a perfect tune on that car you have other problems.
  20. #100 Re: l67 camaro
    Jan 2009
    Tallahassee, FL
    Start at stock then go down from there
    77 Morris Garage B
  1. 97 l32 camaro
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2012, 06:34 PM
  2. So Im trying to buy this Camaro...
    By SuperSport in forum Off Topic Discussion
    Last Post: 01-21-2011, 07:09 PM
  3. LT1 Camaro
    By ls1camino in forum Track Sessions and Kills
    Last Post: 11-21-2009, 02:14 AM
  4. Camaro vs Evo
    By SlowM90 in forum Track Sessions and Kills
    Last Post: 08-30-2009, 03:26 AM
  5. Camaro
    By bloxmagic in forum Track Sessions and Kills
    Last Post: 07-03-2009, 02:09 PM
