Thread: l67 camaro
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 61 to 80 of 110
  1. #61 Re: l67 camaro
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Have fun chopping up that beautifully painted blower.
    04 GTP -HAI, 1.9 rockers.
  2. #62 Re: l67 camaro
    Aug 2013
    Sandy, UT
    Heres my hacked Gen V
    l67 camaro Attached Images
  3. #63 Re: l67 camaro
    Tallahassee ehh!
    04 Comp G.
  4. #64 Re: l67 camaro
    Aug 2013
    tallahassee
    I'm not going to be hacking up the blower. I'm having a bolt on elbow made. And I'll have to cut into the firewall. And yes I am in tally. And it sucks here... used to live in orlando. Really want to move back when school is done lol
  5. #65 Re: l67 camaro
    Aug 2013
    Sandy, UT
    .... Good luck. I don't think you realise how little room there is, and its not just all empty space behind the firewall.
  6. #66 Re: l67 camaro
    Mar 2012
    NC
    I've had the dash out of multiple 4th gens...bye bye heater box...
  7. #67 Re: l67 camaro
    Aug 2013
    Sandy, UT
    I mean if he can pull it off like that and delete whatever is behind there.. more power to him. I just wanted to retain the safety and function of my car.
  8. #68 Re: l67 camaro
    Mar 2012
    NC
    Quote Originally Posted by SnowTh1ef View Post
    The heater box sits against the bulkhead (firewall for those who prefer the non proper term.) The only way to gain clearance will be to pull the dash, heater box, cut the bulkhead, trim the heater box to fit if you can, and go from there.
  9. #69 Re: l67 camaro
    Aug 2013
    Sandy, UT
    This is how I "convinced" my firewall/bulkhead to make room. after cutting a good 4" or so off the blower
  10. #70 Re: l67 camaro
    Never Never Land
    Cut hole in firewall. Stick filter in cabin. Ultimate blower whine?
  11. #71 Re: l67 camaro
    Aug 2013
    Sandy, UT
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    Cut hole in firewall. Stick filter in cabin. Become deaf or wear extreme ear protection
    Fixed that for you.
    Also it'd be coming through where your radio and a lot of electronics/brackets/wiring is... So even that could be tricky.
  12. #72 Re: l67 camaro
    Aug 2013
    tallahassee
    Can I use a 2 bar map sensor from a l67 with my setup for tuning? Or will it not read correctly with my pcm? I hear tuning with the 1 bar map can be quite difficult
  13. #73 Re: l67 camaro
    May 2012
    Where winter never ends
    This seems like its going to end horribly unless you cut the blower back and modify it to fit... Removing the thing that stands between you and a potential fire sounds A) BAD and B) Not track legal...
    2000 Regal - Winter Beater
  14. #74 Re: l67 camaro
    Aug 2013
    tallahassee
    I've seen it done without hacking the blower on another build similar on full throttle forums, that's what I'm basing the idea off of, it was same type of Camaro, even had the electronic throttle body like mine. I'll try to find a link.
  15. #75 Re: l67 camaro
    May 2012
    Still... Why would you do all that extra work when you can just chop the blower, weld on a ubend and have a happy day
  16. #76 Re: l67 camaro
    Quote Originally Posted by adecker View Post
    This!
    04 Comp G.
  17. #77 Re: l67 camaro
    gardner,mass
    Why bother, just turbo..
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  18. #78 Re: l67 camaro
    May 2012
    LOL
  19. #79 Re: l67 camaro
    Aug 2013
    tallahassee
  20. #80 l67 camaro
    I would still rather modify the blower instead of the firewall but that's my $.2
    04 Comp G.
  1. 97 l32 camaro
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2012, 06:34 PM
  2. So Im trying to buy this Camaro...
    By SuperSport in forum Off Topic Discussion
    Last Post: 01-21-2011, 07:09 PM
  3. LT1 Camaro
    By ls1camino in forum Track Sessions and Kills
    Last Post: 11-21-2009, 02:14 AM
  4. Camaro vs Evo
    By SlowM90 in forum Track Sessions and Kills
    Last Post: 08-30-2009, 03:26 AM
  5. Camaro
    By bloxmagic in forum Track Sessions and Kills
    Last Post: 07-03-2009, 02:09 PM
