Thread: 96 f150 p402 p401 codes
Results 1 to 5 of 5
  1. #1 96 f150 p402 p401 codes
    I'm gonna be working on a guys truck that i work with to help him out and I don't want to change any parts that don't need it. The truck is throwing codes for egr insufficient flow and egr flow excess detected which i thought was weird but there was an egr solenoid that was making weird noises every time the truck died so i'm thinking that is the problem. If anyone has an input or experience with this i'd appreciate it thanks.
  2. #2 Re: 96 f150 p402 p401 codes
    I wanna take a guess and say that the EGR is vacuum opened and closed right?
    It could be just that its full of build up and the pintle is being held closed to reduce the flow, maybe the egr valve itself is bad or its the solenoid.
    Start with cleaning it and clearing the codes and go drive it to see if it comes back.
  3. #3 Re: 96 f150 p402 p401 codes
    he wants me to change the egr and egr vacuum solenoid so i'm gonna do that. I told him i could probably clean it but he told me to just replace it so i'll do what the man wants he's paying for it. It is vacuum controled. It's actually so bad the truck won't idle at all it just keeps dying unless you hold the gas.
  4. #4 Re: 96 f150 p402 p401 codes
    St. Louis
    Check the DPFE sensor as it can cause these codes as well and is often overlooked.
    Check out this thread for info...
    EGR Fault P0402 - Ford F150 Forum
  5. #5 Re: 96 f150 p402 p401 codes
    I'm gonna look at his truck tom to make sure it has a dpfe sensor because some don't.
  1. My daytona vs late 90's f150
    By thatguy in forum Track Sessions and Kills
    Last Post: 01-26-2012, 11:50 PM
  2. modded f150
    By Rather B Blown in forum Track Sessions and Kills
    Last Post: 01-16-2010, 08:19 PM
  3. P401 Code On 00 GTP
    By hoont79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2009, 01:59 PM
  4. F150 + Regal + Ram
    By Toofastgs in forum Track Sessions and Kills
    Last Post: 08-28-2008, 05:11 AM
