Thread: Correct way to adapt an L67 from a GTP with automatic onto a manual transmission?
Results 1 to 3 of 3
sparkydog Correct way to adapt an L67... 05-03-2021, 01:37 PM
Turbocharged400sbc Re: Correct way to adapt an... 05-03-2021, 07:03 PM
Bake82 Re: Correct way to adapt an... 05-05-2021, 09:42 AM
  1. #1 Correct way to adapt an L67 from a GTP with automatic onto a manual transmission?
    Jan 2015
    United States
    I've got an L67 off of an 01 GTP and an L36+T5 from a 98 Camaro. What is the correct thing to do with moving the flywheel off the L36 onto the L67? I have read a few threads on the webz and I always end up confused over whether it's just a simple swap or that I have to worry about re-balancing the flywheel.
  2. #2 Re: Correct way to adapt an L67 from a GTP with automatic onto a manual transmission?
    hangover park IL
    i spent 200$ to check 8 flexplates and 2 meziere rebalanced
    early SII L67's could be either 21 or 22 ozin. fwd/rwd na is 20, meziere is 20, later L67/l32 is 21.
    lookup a Balancestar location near you or find a local machine shop.
    if your not beating the hell outta it and keeping it under 6krpm...youd probably be ok as is.......but if your factory tollerances are closer to 22oz inch (remember these engines are getting tollerance stacking during assembly and can be anywherre on the tollerance bellcurve.
    ~James~ Psychotic Gearhead
  3. #3 Re: Correct way to adapt an L67 from a GTP with automatic onto a manual transmission?
    Dec 2014
    Can
    to be 100% sure, I may want to talk with "Fierorog" (facebook, fiero forums). He cuts alot of the f-body flywheels down and re-balanced to be used in a FWD application as needed. Youre won't need to be cut down, but probably should be balanced. I'm sure he would either sell you a new flywheel and balance it, or just balance yours for a reasonable amount of money and it'd be done by someone who does them all the time.
  1. 97-02 Pontiac Grand Prix Manual Dual HVAC to Automatic HVAC Conversion
    By wstefan20 in forum How To Write-Ups/Tech Tips
    Last Post: 09-05-2017, 11:08 PM
  2. 2002 GTP: Converting Manual dual zone climate control to automatic
    By Burbman in forum General Grand Prix Discussion
    Last Post: 06-10-2016, 09:55 AM
  3. 2005 grand prix, convert from automatic to manual
    By clarkin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2013, 05:51 PM
  4. Swapping automatic to manual
    By pjtgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-22-2011, 01:54 PM
  5. converting from automatic to manual
    By 3800John in forum 1991-1994 5 speed Manual (GETRAG 284,282)
    Last Post: 03-29-2010, 07:36 PM
