Thread: L36 + T5 Off 96 Camaro: Need Clutch/Flywheel Advice
Results 1 to 9 of 9
  1. #1 L36 + T5 Off 96 Camaro: Need Clutch/Flywheel Advice
    Jan 2015
    United States
    So I've got this 150-ish k L36/T5 combo that a 96 Camaro is donating to my Porsche 944 project. I'm getting ready to stuff them in for last mockup/first get it to run. Therefore I want the clutch/flywheel/throwout bearing to be in good condition. When I opened up the clutch this is what I found. The shiny flywheel bolt heads correspond to the shiny clutch tabs just inboard of the springs. Does anyone know what caused that? Will it go away if I just order a new flywheel, new flywheel bolts and new clutch?
    Also - if I order a new flywheel, are there any special concerns with balancing it? I thought I remember reading that there are V6 specific issues with balancing flywheels - but maybe that's just when swapping from an auto tranny to a manual one.
  2. #2 Re: L36 + T5 Off 96 Camaro: Need Clutch/Flywheel Advice
    hangover park IL
    the clutch disc was installed backwards from the looks of it. the "hat" of the disc should go towards the pressure plate and the flat side towards the flywheel.
    looks like you found the issue/noise that probably led them to sell it "before the engine knock/etc" got worse
    just get the disc Blanchard ground at an engine machine shop or a local grinder (grindal/etc) and youll probably get at least one more clutch worth of life out of it
    ~James~ Psychotic Gearhead
  3. #3 Re: L36 + T5 Off 96 Camaro: Need Clutch/Flywheel Advice
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    ^ What he said.
    If you're interested I have a Spec Aluminum Flywheel and Stage 3 clutch sitting in my shop doing nothing. $550 shipped! (Has about 2,500-3,000 or so miles on it)
    Lumpy Gen 3
  4. #4 Re: L36 + T5 Off 96 Camaro: Need Clutch/Flywheel Advice
    Jan 2015
    United States
    Thanks guys!
  5. #5 Re: L36 + T5 Off 96 Camaro: Need Clutch/Flywheel Advice
    Jan 2015
    United States
    First the good news - I surfaced my flywheel at work myself (under the watchful eye of the Tool & Die guys).
    But the rest of the news is... frustrating. First the clutch kit came without the throwout bearing so now I lose a week while Rockauto and I play swap parts game.
    And then came the time to bolt the flywheel back on the Camaro L36 and... the bolts that the internet/Rockauto/Oriellys/Ebay and God say should fit DO NOT FIT. My bolts are smaller. The internet reveals no obvious clues or alternate PN's and Rockauto will not exchange with me because they think I am wrong.
    "Correct" bolts are 7/16 (on left) and mine are smaller (Right). I also pulled a bolt out of my L67 and they too are smaller. O?
  6. #6 Re: L36 + T5 Off 96 Camaro: Need Clutch/Flywheel Advice
    you could just re use the bolts that fit. i did as well as many others.
  7. #7 Re: L36 + T5 Off 96 Camaro: Need Clutch/Flywheel Advice
    Jan 2015
    United States
    OK by me - I thought they were TTY tho?
  8. #8 Re: L36 + T5 Off 96 Camaro: Need Clutch/Flywheel Advice
    they are, but many of us reuse them. not as big a deal vs a head bolt. we reuse lim and every other bolt too pretty much.
    i didnt even tq em. just went by german spec, goodentight. they have been in there for over 2 years now, got like 9 track passes, lots of tuning pulls on the street and my right foot daily lol
  9. #9 Re: L36 + T5 Off 96 Camaro: Need Clutch/Flywheel Advice
    Jan 2015
    United States
    Done deal then - same ones going back in. Thanks Scotty.
  1. SFI 3800 flywheel
    By gbgn1 in forum Wanted To Buy - Parts
    Last Post: 06-11-2015, 12:13 AM
  2. L32 Flywheel Help!?
    By trailtoy83 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2013, 05:47 AM
  3. flywheel
    By Eric Whitter in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2013, 06:45 PM
  4. Flywheel position
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 09:34 AM
