Thread: Project LQ4 - V8 S10 - Sold.
Page 15 of 66 FirstFirst ... 513141516172565 ... LastLast
Results 281 to 300 of 1306
  1. #281 Re: Project LQ4 - FULL Transgo HD2 install
    Mar 2014
    Tucson
    Got some goodies today!
    Unfortunately I screwed up. I ordered flexplate bolts instead of torque converter bolts. Oh well. For $22, it's not worth sending them back. I'll use em.
    Time to do something about this
    This should work
    Should be plenty of clearance now
    I've seen more than one person say they've blown this one up at high RPM, but for $17 I'm going to give it a shot. I don't plan to rev the 6.0 to the moon
    More cleaning
    Apparently, whatever paint GM used on the PS pumps will not stand up to Wal-Mart Super Clean...
    Not really in it for looks, but bare metal won't cut it. Gonna need a fresh coat of Krylon tomorrow. Then I can mount the pump, install the pulley and figure out what length I need for a belt.
  2. #282 Re: Project LQ4 - FULL Transgo HD2 install
    the donor truck didnt have hydro boost brakes? looking at the p/s pump. it looks like a normal one. or have you plugged up the other lines?
  3. #283 Re: Project LQ4 - FULL Transgo HD2 install
    Mar 2014
    Tucson
    It did have HydroBoost. One feed (brass plug) and two returns. I don't remember how exactly it was plumbed, but I know the high pressure side split somewhere along the way.
  4. #284 Re: Project LQ4 - FULL Transgo HD2 install
    Mar 2014
    Tucson
    Pump painted and installed. New pulley on.
    Had to push it a little past flush for belt alignment.
    Clean
    Now I can figure out what belt length I need
    Torque convertor bolts came. Need a 10mm tap to chase the holes. Some of the threads got chewed up when the original bolts backed out.
  5. #285 Re: Project LQ4 - The S10 gets some love
    Mar 2014
    Tucson
    With the motor and trans essentially "done" I decided it was time to dive into the S10
    Found a little pack rat damage
    I assume that was from pack rats. A couple of the pigtails have been replaced in the harness. A telltale sign of rat damage
    My $0 impromptu fix. Just a piece of CPVC slid over and RTV'd in place
    Time to get underneath this dirty pig
  6. #286 Re: Project LQ4 - The S10 gets some love
    Mar 2014
    Tucson
    Drained the oil. Whoa...
    Started pulling the front off
  7. #287 Re: Project LQ4 - The S10 gets some love
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    That's a nasty drain plug... Lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  8. #288 Re: Project LQ4 - The S10 gets some love
    looks about the same to me lol
  9. #289 Re: Project LQ4 - The S10 gets some love
    Mar 2014
    Tucson
    Quote Originally Posted by WarStryker13 View Post
    Definitely explains the knock.
  10. #290 Re: Project LQ4 - Fleet truck sleeper!
    Jan 2014
    AR
    Drain plug reminds me of Jughead from Archie comics.
  11. #291 Re: Project LQ4 - The S10 gets some love
    Mar 2014
    Tucson
    More progress
    This thing is a disaster. Sludge all over the engine.
    On the plus side... I saw some writing on the side of the trans. "10/28/08/" I'm wondering if it was rebuilt or replaced around that time. When I pulled the driveshaft, the ATF that came out looked bright red and smelled fresh. Hopefully I can find out more when I have it out.
  12. #292 Re: Project LQ4 - The S10 gets some love
    Oct 2014
    Frederick, MD
    might be able to get a little back from the trans if it's in good shape... MOAR MODS! lol
  13. #293 Re: Project LQ4 - The S10 gets some love
    funny but the truck looks like its launching, wheels off the ground and blew the hood off lol
    that drip pan you got is super boss too, you make that?
  14. #294 Re: Project LQ4 - The S10 gets some love
    Buffalo
    ^ I've had good luck using a hot water tank plastic pan and it came with a few pads
    once those ran out , I snagged some puppy pads on clearance at the pet store.
  15. #295 Re: Project LQ4 - The S10 gets some love
    Mar 2014
    Tucson
    I'm thinking the trans should net about $300. I'll list the motor for $200 and take whatever I get offered. With all the accessories, it should be worth something. Heck, the Sanderson compressor on it's probably worth $50.
    Someday!
    No. Wal-mart... $12 Anyone with an older GM vehicle needs at least two!
  16. #296 Re: Project LQ4 - The S10 gets some love
    ill have to look for it there. second guess was bakers tray. lucky for me, my w body no longer leaks, but that would have been nice for the water pump job i did the other day. i put two drain pans under it and caught most, not all lol. nothing the hose cant wash away, right?
  17. #297 Re: Project LQ4 - The S10 gets some love
    Jan 2014
    AR
    Quote Originally Posted by BrandonHall10 View Post
    Get a couple sticks of pipe and make a knocking drift trike instead.
  18. #298 Re: Project LQ4 - The S10 gets some love
    Mar 2014
    Tucson
    Ha! I'm fairly certain that motor doesn't have more that a couple more hours of life left in it.
  19. #299 Re: Project LQ4 - The S10 gets some love
    Oct 2014
    Frederick, MD
    Let it go out in a blaze of glory!
  20. #300 Re: Project LQ4 - The S10 gets some love
    Mar 2014
    Tucson
    Cash in my hand is glorious!
    So, after playing Goldilocks with the serp belt, I finally got one I'll call acceptable.
    Could be a little shorter, but I can take care or that when I replace this one.
    I think the only thing left before I can pull the engine is the fuel lines. Front has a lift bracket. Need to find a good point for the back.
  1. Replies: 97
    Last Post: 08-08-2017, 08:12 AM
  2. Replies: 17
    Last Post: 12-28-2012, 04:17 PM
  3. Heres a 1997 GTP my friend is interested in. Any good or bad things bout them?
    By burgundybullet in forum General Grand Prix Discussion
    Last Post: 02-21-2012, 02:29 AM
  4. Can't WAIT !!!!
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 07-17-2011, 11:16 AM
