Hey all... my 2004 Impala SS was rear ended on the expressway a couple of months ago (stopped for traffic backup, guy driving van behind me was ****ing around on his phone or something, not paying attention, rear ended me and knocked my car into a ditch) and I've decided to take a break from performance modding. Bought a 1997 Lesabre as a simple, cheap DD. 138K on the clock, new tires, $750.... so not bad for a boring car.
Anyway, replaced all the typical engine parts and gaskets, usual stuff.... but I have a few interior things bugging me and wondered if any of you could offer input:
Horn does not work... found that the horns had actually been disconnected. When plugged in they will blow constantly.
Car chimes constantly if key is not in accessory or run position.... it seems to believe that I am leaving the key in the ignition even if I remove it. This is on the same fuse as the horns, not sure if related. Most likely the key in switch or wiring has an issue, though. No ignition issues at all, however.
Radio controls on the steering wheel do not function. Radio is factory, radio controls on face of radio work fine.
Could all of these issues be related, as they are all on the steering column? Clock spring etc? Or are all the issues likely separate? The multi function switch works perfectly fine. Airbag lights work properly and clear when car starts.
