Thread: brake lights not working
Results 1 to 7 of 7
  1. #1 brake lights not working
    MINNESOTA
    hi peoples.my brother has a 94 cutlass sup.
    and the brake lights dont work or the revers lights,turn signals work,tail lights work,i was reading something about a MFS.how can i find this and tested to make sure it works.or any other ideas as to what might be the problem.thank you
  2. #2 Re: brake lights not working
    GTP Level Member 2001goldGTP's Avatar
    california
    sorry for the long wait, i have a 90 and i had real issues with the brake lights and it ended up being in the steering column, has it ever smoked?
    xp'd
  3. #3 Re: brake lights not working
    GTP Level Member simbah's Avatar
    Lala land
    turn signal switch.... I know sounds funny but that most likely what causes this particular problem, had same issue in my 94 CS
  4. #4 Re: brake lights not working
    MINNESOTA
    Quote Originally Posted by 2001goldGTP View Post
    no, it has never smoked,i replaced the trany and it sit in the garage for about 1 1/2 years and when i took it out the brake lights didnt work
  5. #5 Re: brake lights not working
    MINNESOTA
    Quote Originally Posted by simbah View Post
    so do i replace the turn signal switch.or do you know wich wires i can test to see if there working correctly,thank you
  6. #6 Re: brake lights not working
    california
    change the swich first, when mine went bad the only way to get all the break lights on was to hold the turn signal down, press the brakes and have the driving lights on lol. mine was f'ed but it started with just the turn signal switch needing to be held down to make the signal work
    xp'd
  7. #7 Re: brake lights not working
    MINNESOTA
    thanks.will look in to that switch.thanks again
  1. Non-working Lights
    By tonestace in forum General Tech Discussion
    Last Post: 12-25-2010, 12:55 AM
  2. Fog lights not working
    By GAFF in forum Audio, Security & Visual Electronics
    Last Post: 12-12-2010, 01:59 PM
  3. Interior lights not working
    By jmanrta in forum General Tech Discussion
    Last Post: 11-30-2010, 12:37 PM
  4. Brake Lights not working
    By cwhiteboy in forum Audio, Security & Visual Electronics
    Last Post: 11-03-2010, 07:58 AM
  5. dim lights not working, bright lights ok
    By madmex2k in forum General Tech Discussion
    Last Post: 12-07-2009, 11:27 PM
