Thread: Latest Recall 09047 Engine Compartment Fire
Results 1 to 20 of 24
  1. #1 Latest Recall 09047 Engine Compartment Fire
    SE Level Member Pontiacmaster81's Avatar
    Jan 2014
    New York
    Has anyone received this recall yet, I just received my notice in the mail on Friday and made an apt today. What exactly will they be doing or fixing. Cause my Engine Compartment is extremely Hot you can basically boil an egg on it and I live in New York were Temp is roughly 60 to 70
    2002 PONTIAC GRAND PRIX GT
    "LISTEN! CAN YOU TELL THE DIFFERENCE BETWEEN
    A CAR WITH A BAD TRANSMISSION, AND ONE THAT IS POSSESSED BY A DEMON FROM HELL?"
  2. #2 Re: Latest Recall 09047 Engine Compartment Fire
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    It basically just replaces the front valve cover gasket or add the plastic thing to re direct the oil and plug wires or both. I would just do it yourself because chances are the rear is leaking also which they won't replace for free. I would look around the valve cover for oil build up on the ehaust manifolds. Mine was big enough I could smell oil burning before I did mine.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: Latest Recall 09047 Engine Compartment Fire
    Jan 2014
    New York
    See the big plastic lid that covers the engine the Styrofoam on the back is now laying on my valve cover, I'll have to take pictures so you understand fully but nevertheless I have little tiny pieces of the Styrofoam all over inside where the engine is so hot
  4. #4 Re: Latest Recall 09047 Engine Compartment Fire
    Apr 2012
    Dayton, OH
    Well the engine is gonna be really hot period just how it works. I would take compressed air and blow all of it off. You can just remove the engine cover then no more foam will be on it.
    2012 F150 STX
  5. #5 Re: Latest Recall 09047 Engine Compartment Fire
    Jan 2014
    New York
    Yeah been really busy with College to do the minor details. It's really frustrating though cause some reason like you said I smell Oil burning and other days nothing. Car runs smoothly.
  6. #6 Re: Latest Recall 09047 Engine Compartment Fire
    Apr 2012
    Dayton, OH
    Well if then dealer can do the front one for free do that then do then back one when you get free time unless the rear one is leaking then I would do it ASAP. Good news is when you do the rear one you get to mess with the tensioner/alternator bracket again and those nice coolant elbows.
    2012 F150 STX
  7. #7 Re: Latest Recall 09047 Engine Compartment Fire
    Cleveland Heights, Ohio, United States
    Yesss, I was going to change my front valve cover gaskets but since its free, no need for me to buy em
    1998 Pontiac Grand Prix GT
    1998 Pontiac Grand Prix GTP
    2008 Buick Lacrosse Super
  8. #8 Re: Latest Recall 09047 Engine Compartment Fire
    Apr 2012
    Dayton, OH
    Should have did the back while you had that all torn down. Oh well, least you can remove it in half the time now.
    2012 F150 STX
  9. #9 Re: Latest Recall 09047 Engine Compartment Fire
    I got one in the mail back in February, I just tossed it in the trash, my valve covers have both already been replaced. And on a side note, independent testing has proven that oil leaking on the exhaust manifold is not what causes the fires, its actually the orings in the fuel line disconnects dry rot over time and leak fuel onto the exhaust manifolds.
  10. #10 Re: Latest Recall 09047 Engine Compartment Fire
    Nov 2010
    Baltimore
    Quote Originally Posted by Slick2500 View Post
    Took the words right out of my mouth...leaking oil doesn't have squat to do with it!
  11. #11 Latest Recall 09047 Engine Compartment Fire
    Wht...
    Yea I still wouldn't take a chance thinking that oil spilling on the manifold will not cause a fire seriously... Oil plus a hot manifold = potential fire
    04 Comp G.
  12. #12 Re: Latest Recall 09047 Engine Compartment Fire
    I'm not saying that people shouldn't change a leaky valve cover gasket I'm just saying that the fault behind the fires is not oil.
    And back in my noob days of changing oil I had spilled about 1/2 a quart of oil on the manifold in my old truck and that never started on fire, it smoked like a mofo for about 15 min but all the oil burned off.
    Sent from A Galaxy Far Far Away........
  13. #13 Re: Latest Recall 09047 Engine Compartment Fire
    Apr 2012
    Dayton, OH
    I did that at a gas station and the oil lit up quick and they called the fire department because a lady freaked out. Can wasn't even running for maybe more than 10min in the dead of winter.
    2012 F150 STX
  14. #14 Re: Latest Recall 09047 Engine Compartment Fire
    I do believe that part may be oil.....and here's why.
    GM doesn't appear to have the fire issue on the other body styles, only the W body. Valve covers do leak on all the body styles, so why not recall them to? The only thing I find different when looking at the various changes between the body styles is the front exhaust shield on the W. H/G/C don't have a tight to the manifold shield and sure they leak and sure it smokes..but it doesn't accumulate. The only theory I've come up with is that the shield allows accumulation which over time.. may catch fire.
    In looking at cars in the JY, there appears to be a lot that look like they started the fire at the fuse box. This is another thing many of the other bodies didn't have during 97-03. No fuse box/relay center under hood.
  15. #15 Re: Latest Recall 09047 Engine Compartment Fire
    Donating Users seventone's Avatar
    Mar 2013
    midwest
    Leaky plastic fuel lines a problem as well.
    2 (1997 GTPs) out of 7 of my w body cars have had leaky fuel lines. One had a few pin holes right by the atf dipstick. I got to work smelled gas. I got out popped the hood and fuel was spraying right at my face like a paint gun. Those lines get brittle and crack and leak on to the rear of the engine.
    1997 Black GTP Coupe | 1997 Black GTP Coupe | 2001 Silver GTP Coupe | 2001 Red GTP Coupe
  16. #16 Re: Latest Recall 09047 Engine Compartment Fire
    My engine bay caught on fight with about a cap full of oil so yeah that does cause a fire too, i had to take the dudes bottle of water from in the station to put it out
  17. #17 Re: Latest Recall 09047 Engine Compartment Fire
    Quote Originally Posted by LowRidinCrew View Post
    There was something else in the oil.
  18. #18 Re: Latest Recall 09047 Engine Compartment Fire
    Feb 2010
    TN
    Be careful I had no issues with mine they did the recall two weeks later it caught fire, thank god it was just as I got home and happened to pop the hood to check the oil it made a pop and started a fire the garden hose was two feet away and I saved it. Took an act of congress to get the dealer too look at it again and fix it. They stated they did the job right and car is out of warrenty and Pontiac is out of buisness anyway they did it as a favor to GM, I had to threaten legal action
  19. #19 Re: Latest Recall 09047 Engine Compartment Fire
    Your just assuming at this point just because you haven't experienced oil spilling on the manifold and causing a fire doesn't mean it's not possible right? Why even risk it. Your just arguing something just to argue...
    04 Comp G.
  20. #20 Re: Latest Recall 09047 Engine Compartment Fire
    A cap full of oil isn't going to cause an engine fire I'm sorry but I'm not assuming anything. You are just assuming that I am assuming.
    As bill stated all the other 3800 cars have leaky valve covers and the wbodies are the only ones that start on fire. So let's just keep blaming it on a problem that plauges more cars than just 3800s, how many other engines have leaky valve covers but never start on fire? Still think it's oil?
  1. Engine Compartment Recall?
    By nickgpgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-30-2013, 01:11 PM
  2. Safety Recall 09047 received in mail AFTER incident. Advice?
    By Frank217 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-01-2013, 01:54 PM
  3. Recall 07035 engine fire "warning"
    By chuckd98gtp in forum The Rant Forum
    Last Post: 07-06-2011, 01:35 PM
  4. The Engine Fire Recall?
    By Importz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-11-2011, 07:23 PM
  5. Swap 3.8 (L67) into 3.1 engine compartment?
    By jerricho in forum General Tech Discussion
    Last Post: 05-17-2008, 12:07 AM
