Thread: I can't get my key fob to work...
Results 1 to 6 of 6
  1. #1 I can't get my key fob to work...
    Dec 2013
    pulaski
    I posted the how to I'm trying to follow.. I don't hear a chime after I do steps 4-5. Am I missing something?
    97-03 GP
    IMPORTANT: Before entering programming mode, have in possession all of the remotes you
    will be useing on the vehicle. Once you program the remote. all previous remotes that were
    programmed will be erased from memory. The other remotes will not be functional until you
    program the them again.
    1. Remove the key from the ignition.
    2. Close all doors.
    3. Remove the "MALL PGM" fuse from the fuse panel. Use the legend on the fuse panel or
    *** owner's manual to properly locate the "MALL PGM" fuse.
    4. Insert the key into the ignition, and turn to the ACC position.
    5. Turn the key to OFF and then back to ACC within 1 second.
    6. Open and close any vehicle door. A chime will be heard when the system enters into
    *** programming mode.
    7. Press and hold the remote LOCK and UNLOCK buttons simultaneously for 14 seconds.
    ************* IMPORTANT: After 7 seconds, a chime may be heard confirming successful
    *** synchronization. It is necessary to wait approximately 14 seconds for a second chime
    *** that will confirm successful programming.
    8. Repeat step 7 now for each additional remotes to be programmed including any existing
    * * remotes.
    9. Remove key from ignition.
    10. Install the "MALL PGM" fuse back into the fuse panel and test remote(s).
  2. #2 Re: I can't get my key fob to work...
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Pull the key back for ACC, I did it forward and killed my battery from cycling the fuel pump.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: I can't get my key fob to work...
    Dec 2013
    pulaski
    eghh thats sucks. I tried pulling it back and I tried forward no luck..
  4. #4 Re: I can't get my key fob to work...
    Apr 2012
    Dayton, OH
    Make sure you pulled the right fuse and not the MALL fuse. You sure your doing it right?
    2012 F150 STX
  5. #5 Re: I can't get my key fob to work...
    Dec 2013
    pulaski
    ok thanks for reply.. I'll check again later.
    It might be the wrong fust I probably just went for MALL
  6. #6 Re: I can't get my key fob to work...
    How many chimes does the bcm make? If it only chimes twice your car is not equipped with remote keyless entry.
  1. Replies: 3
    Last Post: 03-01-2013, 08:37 PM
  2. 2007 GXP No gears work and reverse lights dont work
    By MikeJenkins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2012, 06:05 AM
  3. Remote start - Used to work great now after some messing around it does not work.
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 06-12-2012, 11:24 AM
  4. Electrical issues on 98 gtp, Half electronics work most dont work
    By Eric Krawczak in forum General Tech Discussion
    Last Post: 04-30-2012, 10:06 AM
  5. will these work
    By gtcoup in forum Audio, Security & Visual Electronics
    Last Post: 03-05-2011, 10:34 PM
