Thread: Frozen pipes HELP!
Results 1 to 19 of 19
  1. #1 Frozen pipes HELP!
    Mar 2012
    NC
    Got frozen water pipes in half the house. Anyone wanna tell me how to fix this situation? I have no idea how to get under there...stupid cinder block foundation.
  2. #2 Re: Frozen pipes HELP!
    Yoga city
    you need to go buy heated tape or electric heated tap and insulate and wrap your pipes in it and you have no crawl space or anything? when i was in a trailer we would let the water drip at night to keep teh flow up at the farthest part of the house
  3. #3 Re: Frozen pipes HELP!
    You need to heat them...and pretty quick or it's going to be ugggly.
    Once they are heated, you need to insulate them or wrapp them with insulation and a heat tape (like a roof one) that you can kick on when it's nasty
  4. #4 Re: Frozen pipes HELP!
    Mar 2012
    NC
    Well, this is the first time it's been this cold here. The main bathroom and the kitchen both have hot water, but the back bedroom and washer both do not have hot water. The back side of the foundation is covered and you can just see foundation if you look under the porch. I have yet to locate a way under the place.
  5. #5 Re: Frozen pipes HELP!
    Yoga city
    there has to be a way under the house, check closet floors for door or false floors, bills right, if they burst your gonna be **** up the creek. can you say costly? hell if there is no way under they prolly covered it at some point. There has to be a way though.
  6. #6 Re: Frozen pipes HELP!
    Mar 2012
    NC
    You'd think so...but I don't know where.
  7. #7 Re: Frozen pipes HELP!
    Yoga city
    go knocking on **** man, there will be something somewhere, im not there so i cant help lol
  8. #8 Re: Frozen pipes HELP!
    Mar 2012
    NC
    Chances are it's under the porch somewhere...I'll look around and see what I can come up with.
  9. #9 Re: Frozen pipes HELP!
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    I've never had to unthaw pipes, but I've had to go crawling under houses to fix water leaks before. Not fun. Last year I had to dig up a water line that busted in the ground, talk about a *****. Somehow, over the course of several decades, the pipe managed to find a rock in the ground and rub a hole in itself.
    One you get this fixed, wrap it with insulation tape and turn on all the facets to a small stream when it gets really cold out. Running water doesn't freeze.
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    So only half is frozen? Run the faucets that are still running, and open ones that are frozen. The water will flow and be moving just enough to help clear the blockage. I just had this happen to me a week ago. Make sure you have one faucet atleast at a slow drip or you will freeze more of it, i forgot and closed them all and came home the next day to the whole house frozen up.
    Sent using Tapatalk 2 from my GS3.
  11. #11 Re: Frozen pipes HELP!
    Nov 2011
    NY
    It's called heat trace... You'll need to figure on getting a 110/220 volt circuit there but the amperage required will depend on the length of heat trace or pipe being protected is. There are kits you can buy... After heat tracing it'll need to be insulated.
    For temporary fix only, there two things you can do... Find or open access to the underside or crawl space and get a heater in there. A gas fired heated would not be such a good idea IMO, but you could get a few electric heaters and extension cords under there and get some heat in a hurry.
    To keep the pipes from freezing or actually the fluid inside, you could just open the faucets, keep water running and that'll keep it from freezing (within reason). You could open the faucets where frozen and get under there with a torch and heat the pipes to get flow, then it should be ok. You don't want to leave it frozen and faucet closed as the ice expands it could burst pipes, then you gotta fix those too.
    Good luck!
  12. #12 Re: Frozen pipes HELP!
    Once you do unfreeze them, you should leave your water on to trickle out until you can get them wrapped/insulated. This will keep the water moving so it can't freeze as easily
  13. #13 Re: Frozen pipes HELP!
    SE Level Member BANDIT's Avatar
    Ontario, Canada
    Just outta curiosity are there a bunch of houses on your block that look the same, if so, go to the oldest couple on the block and ask them if they know how to get under their house. Chances are a lot of houses were built the same way and they might know. Just a thought.
    04 GP GT Bone stock, just like me! 09 G8 GT...oh yeh!!!
  14. #14 Re: Frozen pipes HELP!
    Pennsylvania
    Open faucet to allow any steam pressure to get out, start working your way down from there with heat gun/torch.
  15. #15 Re: Frozen pipes HELP!
    Apr 2008
    Southern KY
    Quote Originally Posted by BANDIT View Post
    Might be awkward going up to an old couple you don't know, knocking on the door, and asking, "How do I get under your house?"
    Sorry, I started laughing and had to share...
  16. #16 Re: Frozen pipes HELP!
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    That sucks, usually if they freeze they will be issues when they thaw.... good luck.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  17. #17 Re: Frozen pipes HELP!
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    hmm if they are steel lines just hook a welder to it. Ground one end and then put the Stinger on the other end and it will run a current through the pipe. Works everytime for me
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  18. #18 Re: Frozen pipes HELP!
    water lines are copper mostly. at least once they are in your home. the meter forward.
    they ever thaw out Jay?
  19. #19 Re: Frozen pipes HELP!
    Jul 2011
    Michigan
    Either way, if you can run a current through it, it'll work.
  1. Brakes are frozen
    By hulkprix51490 in forum General Tech Discussion
    Last Post: 01-02-2013, 04:47 PM
  2. frozen boost intetcooler kit
    By mskram1 in forum General Grand Prix Discussion
    Last Post: 01-08-2012, 07:33 PM
  3. frozen boost fmhe 118 or 100
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 10:47 PM
  4. Frozen Gas filter
    By Lion29GTP in forum General Tech Discussion
    Last Post: 04-07-2009, 09:52 AM
  5. From the Frozen Tundra
    By highlife70 in forum Introductions/Noob Questions
    Last Post: 01-08-2009, 11:03 PM
