Thread: Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
Results 1 to 18 of 18
  1. #1 Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
    West Side Michigan
    Hey guys, I just bought myself a new TV and mounted it in my room. I moved my xbox away from my modem/router that was in the basement and up to my room. I bought one of these to keep it wirelessly connected:
    The problem is, my room is on the second floor and the signal is coming from the basement. It would cut out, and lag me out of games, it was very frustrating. What I tried yesterday with success is connecting my Xbox to my laptop and enabling internet sharing. This works great, haven't had a problem, but I'd rather not have my computer on plugged in to an outlet (bad battery) just to be able to play Xbox live.
    If anyone has any ideas or tips on how to get this to work (besides to move the router, I'm working on it) it'd be greatly appreciated. And yes I tried making an aluminum foil antennae for my wireless adapter, it definitely didn't help and was the most ghetto thing I have ever made lol
  2. #2 Re: Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    I have the same wireless adapter, and mine does the same random cutting out as you describe. Must be the products fault, not our internet. Im only 10 feet from my router and it does it..
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  3. #3 Re: Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
    West Side Michigan
    Wow.. are you serious? Well I ended up taking my brother wireless adapter and trying his out to compare, he has one of these:
    It worked slightly better but still cut out.. the thing is, my brother is on the same 2nd floor as me and he doesn't have the problem I have. I don't know man, I almost want to return that wireless adapter and get a different one.
  4. #4 Re: Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
    Ontario
    It's really hard. It depends on the type of router you have and what kind of band it is on whether it be G or N. Some bands go through walls better than others. My first suggestion would be to get a more powerful router. I went out and purchased the top of the line Linksys available for residential and small business solutions and that solved a bunch of problems. Other than that, there really is not much you can do besides getting another adapter, or buying the new xbox which has a better wireless adapter.
  5. #5 Re: Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
    West Side Michigan
    See the thing is mine is not just a router, it is for my cable, phone line AND internet, almost everything plugs into it. I did want a stronger router, but I honestly don't know how I'd wire it to work..
    Ethernet cord from one of the ports on the modem to the new router?
  6. #6 Re: Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
    Dec 2008
    Cedar Rapids, IA
    im not sure, I have really good internet. even when my xbox is connected the internet is great. it just randomly 1 or 2 times a night will suddenly kick me off.
  7. #7 Re: Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
    Ontario
    Quote Originally Posted by nawarkk View Post
    You can call your ISP and request to have just a modem supplied to you. You have a router/modem into one right? Or if you're tech savvy, you can disable the router functionality and run it just as a modem. That's what I ended up doing along with purchasing the new router.
  8. #8 Re: Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
    I asked a buddy of mine this same thing...how can I get ethernet to another part of the house w/o running wire....he suggested something along these lines
    Powerline Networking: Powerline Network Adapters - Best Buy
    Use the AC wiring of your house. It's like being hardwired to the router. The above is an example..do your research and get a good model.
  9. #9 Re: Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
    Yoga city
    Can you not just run a cable up to your room? seems like the easiest and wifi suck for online gameplay.
    I live here. DirtDog's Avatar
    Jun 2012
    U could buy a new Xbox with built in wireless...it works flawlessly
    Sent from my pager using Morse code. ... .. ... ....
  11. #11 Re: Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
    Dec 2012
    Rhode Island
    Quote Originally Posted by JTeske88 View Post
    I run wifi on one of my boxes. It works better than the wired one
    Jun 2012
    Ya know I've come to the conclusion that u know something about everything!
  13. #13 Re: Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
    Dec 2012
    Rhode Island
    on another note i would run a cat 6 cable up to the second floor and throw a cheap switch or hub in there
  14. #14 Re: Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
    Quote Originally Posted by marines542 View Post
    Not always true...but I've had some problems to solve and asking friends etc usually nets me an answer.
  15. #15 Re: Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
    Jul 2011
    B-Town, PA
    without going into too much detail i cannot in good conscious recommend the powerline adapters. I used to do tech support for a company and one of their products were a rebranded set of those and the damn things were near worthless.
    If you cannot run Ethernet from the basement to the 2nd floor (like i did) your best bet would be to set up a wireless repeater either on the first floor or somewhere on the 2nd that gets a strong signal. it will pick up on the existing network and rebroadcast it with much improved strength to enable coverage in areas it would normally not cover.
    there are dedicated repeaters or access points and also some routers can be configured in this manner. If you ever wonder how large campuses, companies, and such have wireless all over the damn place that works near 100% all the time? this would be it...
    SMGPFC Member # 569 - Mad Monkey Approved!
    New Ride - 2012 CTS-V Coupe 6spd - Black/black, Recaros. Stock for now.
  16. #16 Re: Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
    West Side Michigan
    Wireless repeater huh? That's exactly what I was wondering existed or not. That's bad ass, I'm gonna have to do some reading on it. I'd rather have strong signal all over the house.
    I've never heard of getting ethernet signal via AC outlet.. hmm I'll have to read some more into it just for interests sake.
    The Boss Iceman6669's Avatar
    Jun 2011
    Most linksys routers you can set up as a wireless access point repeater...
    2011 F-150 Yote powered
  18. #18 Re: Your thoughts: How to keep my Xbox connected wirelessly with a strong signal
    May 2008
    Winnipeg, MB
    I use the Dlink powerline adapters, they work good
    2007 Pontiac Grand Prix
  1. Replies: 0
    Last Post: 04-05-2011, 09:03 PM
  2. 2002 GP GT 3.8L Small Vacuum Line Connected to Brake Booster Fitting At Upper Intake
    By LoveMyGPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-23-2010, 07:51 PM
  3. How many wires are connected to the starter?
    By topswap in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2010, 08:43 PM
  4. Six Months Old and Going Strong
    Last Post: 06-16-2008, 02:39 PM
