Dupli color perfect match. My color code is U331D. What Dupli color perfect match is compatible to this code?
Don't be lazy. Go to advance and look up in there paint code book....find the paint buy it and go about your day.
The reason I was asking is because I was at oreilys and auto zone. Looked in every paint book each place had. Also asked someone who works there if they could find it. My code was not in any book. Figured maybe someone has had an issue like this before and could help. If i wanted a smart ass answer I would have asked for one. Thanks.![]()
I know advance has a good selection of colors.
What year is your car guy?
Try looking in here
http://www.duplicolor.com/scratchfix/
Yeah you have Silvermist Metallic... pretty common in auto stores.
http://www.autozone.com/autozone/acc...ntifier=827000
Some codes are not in the books. However, have them look up scratch fix paint in their computer (Autozone can do this I know) and it will list some paint codes. They can then select your code and tell you if it's available.
In the book the code for silvermist metallic is off by one number when compared to my code. Thus I was a bit confused. I thought it might be that but it wasn't on the shelves either so i couldn't look at it in person.
http://www.grandprixforums.net/my-du...tch-64996.html
This is what I did with the dupli color rattle can
Found a color close to it at oreilys because they didn't make a big can of the silvermist metallic bit made a big can of silver metallic. Only doing the closest color so i can get this gtp ready to sell. If it was one i was keeping for myself for awhile I wud order from Dupli color and wait the 7-10 days.
If you're needing a quick fix, ever considered a paint shop? Two of them around here will mix paint and put it in a spray can for you.
