Thread: would it be a bad ideal to change the supercharger oil at 128,000 miles
Results 1 to 10 of 10
  1. #1 would it be a bad ideal to change the supercharger oil at 128,000 miles
    SE Level Member pontiacmanj2's Avatar
    Apr 2012
    Saint Clair Shores, MI
    would it be a bad ideal to change the supercharger oil at 128,000 miles. Idk if it ever has been change, and what would be a good thing to use to suck out the oil? Thanks Johnny.
  2. #2 Re: would it be a bad ideal to change the supercharger oil at 128,000 miles
    grab a straw and start sucking..
    SMGPFC Member #10
  3. #3 Re: would it be a bad ideal to change the supercharger oil at 128,000 miles
    Omaha, NE
    A lot of people use turkey basters, bottle sprayers or hand pump siphon systems.
    Its NEVER a bad time to change supercharger oil. It always smells great!
  4. #4 Re: would it be a bad ideal to change the supercharger oil at 128,000 miles
    dead dinosaur
    SMGPFC Member #10
  5. #5 Re: would it be a bad ideal to change the supercharger oil at 128,000 miles
    Houston
    If it'll give you peace of mind, do it. If you do, after you drain it, you might as well replace the coupler while you're at it. Then you prolly wont ever need to touch it again.
  6. #6 Re: would it be a bad ideal to change the supercharger oil at 128,000 miles
    Apr 2012
    alright thanks for the info, is there a better type of supercharger oil I can buy instead of GM
  7. #7 Re: would it be a bad ideal to change the supercharger oil at 128,000 miles
    Quote Originally Posted by pontiacmanj2 View Post
    In short, no.
  8. #8 Re: would it be a bad ideal to change the supercharger oil at 128,000 miles
    I live here. TLSheff's Avatar
    GM Maintenance guide in your owners manual states to check and change if needed every 30,000 miles... It most likely has never been done, most people don't even know the supercharger snout HAS fluid in it . Do it... Do it now.
  9. #9 Re: would it be a bad ideal to change the supercharger oil at 128,000 miles
    Baby seal oil.
  10. #10 Re: would it be a bad ideal to change the supercharger oil at 128,000 miles
  1. Supercharger oil change?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2011, 12:49 AM
  2. Supercharger oil change????
    By chevyy1212 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2011, 06:36 PM
