Thread: Upgrading graphics card?
Results 1 to 20 of 22
  1. #1 Upgrading graphics card?
    Jun 2011
    Detroit, MI
    I'm looking to upgrade my gfx card on my Dell Studio XPS 8100. I was wondering if I would be able to upgrade to a 550w power supply, with no problems, and what one you recommend (need good price). I would also like to know if the GeForce GTX 550 Ti would be compatible on my computer (fitment etc.).
    Here is my current setup:
    Windows 7
    Intel Core i5 CPU @ 3.3GHz
    350w Power Supply
    8GB RAM
    GeForce 310 (1/2GB video ram)
    DirectX 11
    Please help, I want to have HD and high quality games now and in the future!
    iLoveSpade
  2. #2 Re: Upgrading graphics card?
    You need to know what your motherboard is compatable with.
    Dell likes to make everything use their own "proprietary" connectors.
    Now IMO, to max out every game available you'd want a GTX 580 or one of the new AMD cards that are supposed to come out soon.
    Want to be able to play most games well? 560 Ti or a 6950.
  3. #3 Re: Upgrading graphics card?
    Kansas
    What Matt said, you should be able to pickup a new PSU and throw it in. But Dell likes to be retarded sometimes. Corsair makes good PSUs.
  4. #4 Re: Upgrading graphics card?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    any good graphics card will need more then a 350 watt powersupply, powersupply probably wont have the right connections either.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  5. #5 Re: Upgrading graphics card?
    Donating Users
    Deland, IL
    any card that is a PCIe x16 should work. try newegg.com or tigerdirect.com
  6. #6 Re: Upgrading graphics card?
    work? yes.
    perform? no.
  7. #7 Re: Upgrading graphics card?
    Kansas
    PSU should work, 24 pin EPS 12V, ATX compatible.
    Dell - Support
    Check out maybe something like this?
    Newegg.com - CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
    or you could probably get away with a 500W. Unless you plan on someday going crazy with modding.
    Edit: Dell link doesn't work, just goodle XPS 8100 board specs
  8. #8 Re: Upgrading graphics card?
    Jun 2011
    Detroit, MI
    GTX 580 is way too high, the GTX 550 ti is good enough I believe, for only $110. If you have any reason I shouldn't get that, let me know.
    So there shouldn't be any size issues?
    Thanks for the replies.
    Also for a ps I was thinking this: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341047
    I
    'm looking to keep it cheap
    iLoveSpade
  9. #9 Re: Upgrading graphics card?
    Well if you can't max out the game, then its not high quality.
    A 580 probably wont be able to max out games past a year from now.
    A 550 Ti is worse than a 460.
    I've run a stock 460, its okay. Overclocked the crap out of it, much better.
    Now I'm running two. Finally able to run games maxed out and float between 50 and 60 FPS at 1920x1080.
    So really the resolution you desire determines how much power you need.
  10. #10 Re: Upgrading graphics card?
    Jun 2011
    Detroit, MI
    My current display mode is only 1600x900, if i get a 460 what would be a reasonable rez?
    My current gpu G3D rating is 274, so upgrading to the GTX 460 would be a huge gain at 2369 G3D
    iLoveSpade
  11. #11 Re: Upgrading graphics card?
    Midget Amputee Fortehluls's Avatar
    Nov 2011
    New York
    Go AMD, screw nvidia its green... Red is much better.
    2004 Comp G mods:Plog, 10.5mm wires, 3.6 pulley, Full ZZP 2.5" catback, Overkill tune.
  12. #12 Re: Upgrading graphics card?
    Yes.
    Their drivers are so much better.
  13. #13 Re: Upgrading graphics card?
    Nov 2011
    New York
    The whole AMD drivers thing was actually true.. in like the 90s.
  14. #14 Re: Upgrading graphics card?
    Jun 2011
    Detroit, MI
    Yes.
    Sarcasm?
    iLoveSpade
  15. #15 Re: Upgrading graphics card?
    Topeka, KS
    OCZ power supplies are crap don't get one. I had one randomly shut off on me once a month then it got to once a week. Buy that one Negative linked. Personally I would go no lower than a 600watt. I replaced it with a corsair similar to this one. Don't skimp on the PSU. $89.00 is a good price. Spend the extra 10 dollars to know you are getting a quality product.
  16. #16 Re: Upgrading graphics card?
    Kansas
    I bought a new OCZ StealthXStream from a friend for cheap, it died in a month. I've had to send it off twice, and each time they just sent me a new refurb. Finally I *****ed enough and got a new one that still runs good. No issues, but the issues prior are not worth it. Stick with a Corsair and you should be good. And you don't want to skimp on a PSU like Ryan said, thats when you can start ****ing **** up.
  17. #17 Re: Upgrading graphics card?
    Nov 2011
    New York
    I haven't had good luck with OCZ Ram...
  18. #18 Re: Upgrading graphics card?
    Donating User Odi's Avatar
    Chicago South Suburbs
    msi twin frozr 460 768mb works great on sub 1080p resolutions.
    im running it @ 1400x900 and get high on multi bf3 with AA and some options on ultra.
    skyrim maxed out w/ some better texture mods and doesn't drop under 40 fps in bad spots.
    yes, its overclocked about ~15%. card cost me 100 bucks.
  19. #19 Re: Upgrading graphics card?
    May 2008
    Winnipeg, MB
    there is still a pc graphics card market?
    2007 Pontiac Grand Prix
  20. #20 Re: Upgrading graphics card?
    Those things love overclocks.
    I'm just disappointed I couldnt' run 1 GHz with stability.
    Also it seems everyone used to love OCZ around the time of DDR and DDR2.
    DDR3 rolls along and everyone jumps the ship and headed to corsair.
    Now OCZ products are actually difficult to find locally and all they stock is corsair.
  1. Any gps with graphics??
    By Bluemagic in forum Visual/Body Modifications
    Last Post: 03-20-2011, 09:36 PM
  2. card question
    By kjohnson in forum Off Topic Discussion
    Last Post: 11-16-2010, 06:35 PM
  3. graphics
    By hookumup in forum Off Topic Discussion
    Last Post: 12-22-2009, 02:09 PM
  4. anyone like graphics??
    By fabz77gp in forum General Tech Discussion
    Last Post: 03-05-2009, 05:35 PM
  5. New debit card
    Last Post: 01-24-2008, 06:38 PM
