Thread: honda brake job
Results 1 to 20 of 20
  1. #1 honda brake job
    i just picked up a brake job, its a 99 honda accord. any one here know what type of bolts hold the calipers on? regular bolts, torx or something else? i don't normally work on imports but the money will be nice.
    trying to save a trip to the parts store for a lousy tool. i want this to be a one stop shop. ill have the parts before the i get the car.
  2. #2 Re: honda brake job
    Kansas
    From what I came up from googling and replacement caliper pins, I seen regular bolts.
  3. #3 Re: honda brake job
    thanks, im i little f ed up right now lol i forgot about google
  4. #4 Re: honda brake job
    Kansas
    Lol... from what I seen it was all regular.
  5. #5 Re: honda brake job
    Norristown, PA
    Some of the best things are found on google when F'd up
  6. #6 Re: honda brake job
    Omaha, NE
    I hope you aren't doing rotors as well. I know on my 94 accord the rotors are BEHIND the wheel bearings making it a PITA job to do.
  7. #7 Re: honda brake job
    lets hope its not like that im doing the front rotors for sure, he ate it, i told him 2 weeks ago to do the brakes, but he waited till it went metal to metal.
  8. #8 Re: honda brake job
    they should be pretty easy to do, the rotor are infront of the wheel bearing, so your safe there.
    The caliper I think are screw in style, again not a issue.
    Its a pretty straight forward job.
  9. #9 Re: honda brake job
    GT Level Member Tea Time's Avatar
    New Brunswick
    just hex head bolts...nothing crazy like the torx on a sunfire lol
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  10. #10 Re: honda brake job
    ok i can breath again lol sounds like a normal brake job. never know till its on a jack.
  11. #11 Re: honda brake job
    New Brunswick
    lol...no one said they weren't goin to strip once ur into the project..lol
    just razzin ya!
    OK...SERIOUSLY, THATS NOT FUNNY AND I PROBABLY SHOULDN'T HAVE SAID IT.
    '97 GTP - Project
  12. #12 Re: honda brake job
    its funny cause its true lol
  13. #13 Re: honda brake job
    New Brunswick
    i wont be held accountable if anything strips and / or breaks on this project...
    '97 GTP - Project
  14. #14 Re: honda brake job
    GT Level Member RegalGS98s's Avatar
    NJ
    I have a little too much experience with Honda's as I replaced literally every part including the Engine and Transmission except the Unibody of the vehicle on my 95 Accord. 94-97 the front brake rotors are behind the bearing hub which makes it a pain the first time you experience it, but now I do it pretty quick with extended bolts and an air chisel. For 99 the rotors would be normal except Honda decided to put 2 phillips head screws on the rotors. You need heat from a propane torch and an impact hammer. I use this one Impact Screwdriver Set with Case If you strip the threads you'll need to drill them out. I usually break the Phillips bits in the set and have to turn it in for the lifetime warranty by the end of the job. I didn't have any propane so I got one screw out on each side, but then had to drill out the other 2. I forget for 99, but if you're replacing the rear rotors, they have the Phillips screws in the 94-97 with rear discs. The calipers for the rear are screw in and the fronts are regular push in. For my rear caliper screw ins, I use this: 18 Piece Disc Brake Pad and Caliper Service Tool Kit (They have stores in NJ and I always use their coupons) You can usually just screw them in with needle nose pliers, but I had to use that tool as the rear brake line was shot and the one caliper was frozen. After I broke it loose, it works good now.
    So, recommended tools besides the usual:
    Impact screwdriver
    Propane torch
    Disc brake pad and caliper service tool kit
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  15. #15 Re: honda brake job
    so what if i have to drill these Philips head screws out? do they need to be replace or do i just slap on the rotors like a normal car?
  16. #16 Re: honda brake job
    NJ
    Sorry, I knew I forgot something. Everybody I know including me throws them away. They're basically there to line up the rotor without the wheel on. When you torque the wheel back on, they'll be like any other set of rotors.
    O and one more tool, a 2-4 lb sledge hammer for the impact screw driver.
  17. #17 Re: honda brake job
    thanks for the info, damn foreign cars.
    twist in calipers, never knew that, could have been a fun time fvcking them up lol i appreciate that heads up.
  18. #18 Re: honda brake job
    NJ
    NP, I hate working on them, but I know a bit about them. Only the rear calipers are twist in. I think because of the emergency brake.
    I'm always saying f*ing Honda, f*ing Honda. But Nissan is probably the worst because everything is designed to be so cramped. Sister's boyfriend has 2 300 ZX's. One of them the twin turbo. They're always fun to work on when he asks for a hand
  19. #19 Re: honda brake job
    that was a fun little job, turned out he was on the squealers and had some pad left, the rears turned out to be drums, all the drums and rotors were in nice shape so he wanted to save money so i just did the pads and shoes.
    nice spring clip on the rears too, that holds the shoes to the backing plate, what moron came up with that crap idea.
  20. #20 Re: honda brake job
    NJ
    You made out lucky then. My original 95 Accord had the drums, the replacement 95 Accord now has the discs all the way around and so did the later year Accords I've worked on. I remember cursing at those rear shoes a couple times. I was about to convert it to disc. They do other stupid stuff like a second air idler control of sorts in the throttle body. The car had a high idle like almost 2k and I couldn't find anyone with information on what would cause that besides vacuum leaks, EGR valve, and open air idler control. So I took it to a mechanic for the first time in 6 years. He modifies Honda's in his spare time. He fixed it and worked for a week and then back again. Drove me nuts so I disassembled the entire intake to find a plastic screw of sorts in the bottom of the throttle body. Screwed it back in and no more extremely high idle.
  1. Honda
    By AmericanRiceEater in forum Off Topic Discussion
    Last Post: 08-12-2010, 03:36 PM
  2. Bye Bye Little Honda!!!
    By AZGXP in forum Track Sessions and Kills
    Last Post: 08-21-2009, 09:49 PM
  3. If I Had a Honda
    By blueguy in forum Off Topic Discussion
    Last Post: 05-03-2009, 09:54 PM
  4. Honda
    By DOUGLASMELTER in forum The Rant Forum
    Last Post: 04-10-2009, 05:19 AM
