Thread: GM Service Manual DVD
Results 1 to 18 of 18
  1. #1 GM Service Manual DVD
    GT Level Member Panzer4's Avatar
    Dec 2008
    Dubai, UAE/Camarillo, CA/New Delhi, India
    Just wondering if anyone here has used or tried this? Its got repair instructions/bulletins etc for a bunch of GM cars between 98-05. Have used it so far for work on the GTP and the Vette and its been extremely useful and since I downloaded it, I saved ~400$.
    I could post a torrent download link if anyone's interested for this but am not sure if its against forum rules.
    "Cry Havoc! And Let Slip the Dogs of War!"
    Black 2000 GTP: 3.4" Pulley, Resonator/U-bend delete, 180 T-stat, Tuned PCM, Thrasher Intake, Larger Radiator, 17" Konig Tantrum Wheels, Red Air Dams. Coming Soon...Projectors, Lighting Mods, Transmission Cooler, Black Rims, Tinted Tails and hopefully Headers
  2. #2 Re: GM Service Manual DVD
    I have one that I bought. Covers 98-10. Can't tell you how good of a tool it is. Especially when electrical schematics/routing is involved.
  3. #3 Re: GM Service Manual DVD
    GT Level Member GtpKo's Avatar
    Best place on Earth
    How did you (legally) download it? Does GM make it available for free then? I have used it on another forum that has it. It would be nice to have it here as it is a goldmine of information.
    2002 GT F23 5-speed swapped, SPEC stage 2+ clutch, ZZP Power Logs, E-brake handle swap.
  4. #4 Re: GM Service Manual DVD
    Banned
    Sioux Falls, SD
    I would love to have one on my laptop, for when i dont have internet
  5. #5 Re: GM Service Manual DVD
    Dec 2008
    Quote Originally Posted by GtpKo View Post
    Nah sorry brah it definitely isn't free from GM. If you use Bittorrent on the other hand...
    I don't know if you can legally download it, but GM can send you a copy through mail-order. That only works in North America though, not here in Dubai.
  6. #6 Re: GM Service Manual DVD
    Dec 2008
    Agreed. I'm actually going to use it to tap wires for the puddle lights mod you described on my GTP and maybe even on my sisters Vette, if she'll let me .
  7. #7 Re: GM Service Manual DVD
    Yeah..that's how I found which wire and on the previous years..which cavity in the door connector that should be put into. Yeah..I'm crazy.
  8. #8 Re: GM Service Manual DVD
    Dec 2008
    Quote Originally Posted by miker56 View Post
    Well, you can get it from link below. I'll post the link and if mods get pissed they can remove it.
    http://thepiratebay.org/torrent/3591423/GM_Techline_eSI
    Enjoy.
  9. #9 Re: GM Service Manual DVD
    Dec 2008
    Its a good kind of crazy dude! It helped me isolate the ambient air temp. sensor on the radiator baffle so that my climate control stops driving me crazy.
  10. #10 Re: GM Service Manual DVD
    Best place on Earth
    Please excuse my ignorance, but whats the difference between the GM serv man, and All Data? Which is better for our cars?
  11. #11 Re: GM Service Manual DVD
    Dec 2008
    Nothing ignorant about it dude, especially since I have no idea about All Data. What I do know is that you have to pay for All Data, and since I'm currently unemployed that's not an option.
    For what its worth, I've heard good things about All Data.
  12. #12 Re: GM Service Manual DVD
    GT Level Member RegalGS98s's Avatar
    NJ
    All Data has good info, but can be a pain to navigate thru sometimes when you know what the issue is, but just need to know some wires or such. It makes you go thru the whole diagnosis procedure. If you don't know where to start, the All Data is a good teacher. I havn't used the GM Service Manual yet so can't say anything about it. My favorite is Mitchell 1 ondemand 5. I found it easy to navigate and it also has a shoptime quote section so you can figure out how much it will cost or how many hours it will take. Noticed in Pepboys they use it.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  13. #13 Re: GM Service Manual DVD
    The GM FSMs were written by the guys that designed and built the car. Wiring for example is clear and concise in all info right down to "...this wire splice is located 23mm from this piece holding the loom to the firewall.: It's that good. Mitchell aka AllData is darn close. It's my second favorite. Basically it's just a rewrite of the GM manual.
  14. #14 Re: GM Service Manual DVD
    Dec 2008
    Just to update: It seems our friends over at GPONA have had this on their website for a while. Here is the link.
    http://sm.gpona.com:9001/si/home.do
    Used this to get to my blend door actuator today. Useful, except that they don't label pics.
  15. #15 Re: GM Service Manual DVD
    MO
    Yup. It has definitely saved my behind a couple times. Great resource.
    <brandonl2000> LMAO D!!
  16. #16 Re: GM Service Manual DVD
    Puyallup, WA
    Just registered at there forum, but I still cant access the manual.. Any suggestions?
  17. #17 Re: GM Service Manual DVD
    USA
    Quote Originally Posted by CSlater21 View Post
    All lowercase for your name.
    You may need a 100 post if that doesnt work. I think I read that somewhere. Not 100% sure tho
    Bunnell, FL
    My name works there but I have almost 14k posts there
    Android Fire
    I'm a Sex Offender
  1. Comments Wanted - 05 Comp G Service Stability/Service Traction
    By JD05CompGTP in forum General Tech Discussion
    Last Post: 03-13-2012, 08:21 PM
  2. Need 03 GT Service Manual
    By racerj782002 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-18-2010, 01:04 AM
  3. Service Manual? Moving DRL to marker lamps
    By ChicagoGXP in forum Visual/Body Modifications
    Last Post: 04-13-2010, 12:30 PM
  4. need a 99 GP GT service manual
    By Roanokegprix in forum General Tech Discussion
    Last Post: 07-10-2009, 01:52 PM
  5. 2001 service manual
    By Jakegday in forum General Tech Discussion
    Last Post: 11-16-2008, 03:59 PM
