Thread: Rebuilding an Engine, Steam Cleaning Internal
Page 3 of 3 FirstFirst 123
Results 41 to 59 of 59
  1. #41 Re: Rebuilding an Engine, Steam Cleaning Internal
    Spending two grand for upgrading to forged pistons (no other forged parts availible) isnt worth it.
    You're better off investing in HPT and a wideband and learning to tune.
  2. #42 Re: Rebuilding an Engine, Steam Cleaning Internal
    Florida
    I agree with that..
    With the power that the stock pistons can handle, on a properly running engine, theres no need to bump up to forged pistons.
    Just spend the money elsewhere. Get a good wideband, and make something custom for the car.
    I'd just strip it to the short block, and go from there, no need to rebuild the bottom end, or mess with it any.
  3. #43 Re: Rebuilding an Engine, Steam Cleaning Internal
    Largo, Florida, United States
    I agree with that..
    First off, they use a forged process when creating their pistons, which results in a much stronger metal. Not only that, but they use a 2618 aluminum alloy which is much stronger than stock, can handle large amounts of boost and ignition timing, and has minimal expansion.
    They have also moved the first ring groove farther down on the piston to give a thicker, stronger piston top. Then to top it off (pun intended), they offer an optional ceramic thermal coating on the piston tops which reflects the heat and reduces heat soak on the pistons and the piston skirts are moly coated for scuff resistance.
  4. #44 Re: Rebuilding an Engine, Steam Cleaning Internal
    Donating Users kfish's Avatar
    Ohio
    they also make your 3800 sound like a diesel.
    <nawarkk> listen maybe I like being gay
    <rynoman03> my dildo i have is old
    <01GTP> my penis is chrome plated
  5. #45 Re: Rebuilding an Engine, Steam Cleaning Internal
    Apparently only if they're installed wrong.
    Again, forged is a good idea but you must have some expensive tires in mind for putting this to the ground lol.
  6. #46 Re: Rebuilding an Engine, Steam Cleaning Internal
    i just dont want to have any piston related issues down the road. like i said cash wasnt the issue lol i 12 month deployment to iraq is a nice chunk of change and tax free.. and i just dropped 2 grand into suspension/brakes so whats another 1k on forged pistons & connecting rods?
    I'm debating which Cam to go with. (S1X?)
    also wondering if i should switch to a GEN-V before i order the intercooler and ****.
  7. #47 Re: Rebuilding an Engine, Steam Cleaning Internal
    Charles City, IA
    Are you going to run faster than 8.65 and have 700hp? if not you do not need forged pistons.
    SMGPFC Two Nipple General
  8. #48 Re: Rebuilding an Engine, Steam Cleaning Internal
    If you've got money to burn.
    sure. Buy a Gen V and intercooler.
    For the cam, DD or weekend warrior?
  9. #49 Re: Rebuilding an Engine, Steam Cleaning Internal
    DD/Track car. considering buying a bike or a DD when i get back from iraq so this car might become track/show car only but currently looking for Power
  10. #50 Re: Rebuilding an Engine, Steam Cleaning Internal
    Thinking about twin charging this *****.
    seriously.
  11. #51 Re: Rebuilding an Engine, Steam Cleaning Internal
    Charles City, IA
    thats dumb, unless you are an awesome tuner and want to be different.
  12. #52 Re: Rebuilding an Engine, Steam Cleaning Internal
    Charles City, IA
    If you want to make a lot of power twin charging is not what you want to do .
  13. #53 Re: Rebuilding an Engine, Steam Cleaning Internal
    So...what are you going to do about your supercharger?
    It says 3.4" on the snout.
  14. #54 Re: Rebuilding an Engine, Steam Cleaning Internal
    Minnesota
    If your going gung ho on it then go f*#@ing gung ho on it lol go gen v IC crazy cam e85, if i was you I would learn to tune and pick up hp. but what ever you decide to do it sounds like its gonna be insane, its gonna be a highly antisipated build for sure
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  15. #55 Re: Rebuilding an Engine, Steam Cleaning Internal
    Quote Originally Posted by Ricky21 View Post
    Forged Pistons and an Intercooled S1X or XP are far from insane.
  16. #56 Re: Rebuilding an Engine, Steam Cleaning Internal
    Actually i took that off awhile ago.
    its a work in progress but i think it will throw down some serious power when its done.
  17. #57 Re: Rebuilding an Engine, Steam Cleaning Internal
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    yes. Insane is more along these lines:
    Tranny from this:
    Engine and rest of powertrain from this:
    and you basically get this (but better):
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  18. #58 Re: Rebuilding an Engine, Steam Cleaning Internal
    Charles City, IA
    yeah the gpx did not have a 6 speed. It just had the awd 4t-65 from a minivan.
  19. #59 Re: Rebuilding an Engine, Steam Cleaning Internal
    Nov 2008
    Waterloo, Iowa
    And the Aztek...
  1. engine cleaning
    By busagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2010, 08:53 PM
  2. releasing some steam
    By cojo in forum The Rant Forum
    Last Post: 04-13-2009, 08:49 PM
  3. Cleaning up the engine bay
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 07:22 PM
  4. Cleaning up engine
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 09-25-2008, 03:26 PM
  5. Cleaning Engine Bay
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 08-19-2008, 01:42 AM
