Thread: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
Results 1 to 18 of 18
  1. #1 Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    Every now and then I come across something truly impressive. This represents some of the work of Extreme Tuners in Athens, Greece, and the name is no joke. Pushing limits requires funds and skill, and these guys have both. All they do is build and tune engines. The entire lengthy discussion can be found here (http://forums.evolutionm.net/evo-dyn...ne-2007-a.html), but unless you feel like reading quite a few pages of posts, I'll post the highlights here.
    FWIW, this is some of what they've done:
    2006 - N/A ford cosworth 4cylinder 16v engine 119cui: 416hp -11,900rpms
    2007 - Ford cosworth 4cylinder 16v Turbo engine 120cui: 1280hp 47psi (custom triple ball bearing 80mm turbo 119lbs/min)
    2007 – Mitsubishi Evo 8 4g63 4cylinder 16v Turbo engine: 1416hp – 57psi (custom quad ball bearing 82mm turbo 132lbs/min)
    So, getting 700whp/L from 2.0L @ 8500rpm is no small feat, but what do you need if you get bored and want to shoot for 2000whp?
    Cast Garrett compressor wheels (right) tend to come apart above 50 psi. CNC billet aluminum wheels (middle) are stronger, but why not be different and use your own CNC billet titanium (left) compressor?
    You'll need a turbo big enough for the job, which in this case is a 108mm twinscroll T4 turbo, with custom quad ball bearing CHRA and 100psi capability.
    To get enough airflow at 12,000rpm(!) to get the job done, you'll need a skillfully ported head, complete with titanium valves and copper-beryllium valve seats:
    And you're going to need a set of camshafts to handle the rpm and withstand tremendous ramp pressures, so why not a set of hollow titanium billets with DLC at only 234 grams each?
    And since there is no aftermarket rod up to the task, just ask for a set of billet mmcs-titanium connecting rods at 286g each. Rod/Stroke ratio is 2.07:
    Toss in a custom titanium billet crank:
    A set of 9000cc/min injectors:
    And since a factory 4G63 block probably wouldn't hold up, just CNC machine your own from billet aluminum:
    No headgasket Needed:
    And to put all that power to the gearbox, one needs a suitable multiplate clutch:
    Yes, it is smaller than a cam gear:
    An example of very efficient turbo manifold design from one of their recent projects:
    And last but not least, a dynosheet from this car, running 'only' 48psi and hydraulic cams:
    Highest HP 4g63 engine (from 2007) - evolutionm.net
    Totally Awesome, I would love to have a build like this some day, but thats the cost of a kidney LOL
  2. #2 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    GTP Level Member KwazrollinZ28GTP's Avatar
    FLINT/michigan
    holy crap
    1997 GTP 2DR RaceKAR
    1994 Z28 intake, small cam, exhaust leak
    2000 silverado 5.3l Z71 3.73gear posi, 3.5" lift 33" tires DIABLO Tune
  3. #3 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
  4. #4 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    Arizona
    heres a someting from a rc drift forum i used tpo go on... this guy buils a scale miata with interior, opening doors, trunk and hood. his detail is so precise its amazing
    Board Message
    '00 GT- nothing special
  5. #5 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    What was the point of quoting it?
  6. #6 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    Arizona
    i just noticed that too
  7. #7 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    i would love to have that 4g63 build. but with the money id rather buy japan.
    2000 Daytona GTP(aka the slow fwd GTO)
  8. #8 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    It doesnt make any power till 6500 RPM...
  9. #9 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    But it makes a gazillion HP from 6501 to 99,867 rpm.
  10. #10 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    Yeah.... so much power that you'll go from Okay waiting for power to......... BURNOUT IN FIFTH GEAR WOOOOOOOOOO
  11. #11 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Um, yes please!!! I'll take two...
    Lambokit to be built!!!!!
  12. #12 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    So nobody thinks I'm actually building this....I've gotten a PM on something I posted on other forums saying how sick it was I did that, and I was like
  13. #13 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    Jersey
    that car is sick. i love evos
    16' wrx sti- stock
  14. #14 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    bump
  15. #15 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    you dont bump threads like this.............
  16. #16 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    its a build thread thread...
    I see some threads that are posting builds.
  17. #17 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    Arizona
    pretty sure a lot of you have seen these but here they are anyways
    YouTube - Death of a Trans Am
    rebirth
    http://www.youtube.com/watch?v=IuqAvtSrnSA
  18. #18 Re: Sometimes...some builds are just beyond amazing - Post sweet ass Build threads
    Jan 2009
    Tallahassee, FL
    That is a sweet build but there is nothing EVO about the build other than that's the chasis it's mounted in lol
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  1. This is an amazing forum with great people and this has just hit me....
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 09-14-2010, 10:29 PM
  2. Amazing Crash Proof Motorcycle!
    By alkygto in forum Off Topic Discussion
    Last Post: 08-14-2010, 03:53 PM
  3. Grand Prix Builds How much....
    Last Post: 04-11-2010, 03:41 PM
  4. Obama is amazing!!
    By Mad Monkey in forum Off Topic Discussion
    Last Post: 09-29-2009, 09:03 PM
