Thread: Not the gas cap
Results 1 to 10 of 10
  1. #1 Not the gas cap
    Nov 2010
    Madison WI.
    I went to autozone about my check engine light on my 97 grand prix GT they said it was the gas cap so I replaced it but the light is still on any sugustions?
  2. #2 Re: Not the gas cap
    Akron Ohio
    Did you clear it?
  3. #3 Re: Not the gas cap
    Donating Users Rust's Avatar
    Jun 2010
    Canada
    Might take a few starts and drives for it to go away if that was the only problem.
  4. #4 Re: Not the gas cap
    Largo, Florida, United States
    while you are at it get a locking gas cap!
  5. #5 Re: Not the gas cap
    Charles City, IA
    Could be any part of the evap system leaking.
    SMGPFC Two Nipple General
  6. #6 Re: Not the gas cap
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    if they said it was a gas cap it was prolly that stupid evap leak code. usually it is a gas cap but it can also be a rotted vacuum line or the canister purge. also do you ever keep the car running while pumping gas? this will kick the code. usually it will go out by itself but just have them clear it.
    2000 Daytona GTP(aka the slow fwd GTO)
  7. #7 Re: Not the gas cap
    SE Level Member Paul79UF's Avatar
    Florida
    You can try unhooking the battery for a few hours to try clearing the code.
    I had the same problem with my '01 GTP. A new gas cap did solve the problem.
  8. #8 Re: Not the gas cap
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    Not all of the aftermarket caps seal correctly. I had that problem with mine, and it didn't clear with the aftermarket gas cap. After I took it in to a shop to be diagnosed, they replaced the cap with a factory one and it worked fine.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  9. #9 Re: Not the gas cap
    Donating Users busmech's Avatar
    Apr 2009
    Minneapolis MN
    Yes,they can be very touchy...there is a factory spec for a gas cap...some of these crappy Chinese aftermarket parts dont cut it...Ford had so much trouble they went to no cap at all on some stuff...bottom line,spend the extra money,get a GM cap...
    "Turbocharging is nice...but I'd rather be BLOWN!!!
  10. #10 Re: Not the gas cap
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Quote Originally Posted by buemech View Post
    YEP!! ^^^
    Cheaper is not always better.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
cap, gas
