Thread: electric arch going from belt to any ground when engine is running
Results 1 to 12 of 12
  1. #1 electric arch going from belt to any ground when engine is running
    SE Level Member chev1988rolet's Avatar
    Jul 2010
    TX
    about a year ago i noticed an electric current or a visible arch in the dark going from the drivebelt to the bracket right above my power steering pump when my engine is running. i can also see it when i put any metal object real close to the belt when my engine is on. i put the lead from my voltmeter and it reads 20-60 volts in the arch. has anybody ever seen this before. i dont think it affects anything but its wierd how its a postive voltage going directly into the block which is ground. i looked online and saw something about water getting into my powersteering pump and making electricity when pump is spinning like some type of generator.
  2. #2 Re: electric arch going from belt to any ground when engine is running
    Portland Oregon
    Um, that's weird
  3. #3 Re: electric arch going from belt to any ground when engine is running
    Jul 2010
    TX
    yea i was freaked out too since the highest amount of volts in a car should be around 14 to 15 volts. i think thats probably why i see small blinking archs on my spark plugs as if my wires were no good but i've changed wires, plugs, ignition module and coils.
  4. #4 Re: electric arch going from belt to any ground when engine is running
    did you put the electric grease on the boots too?
  5. #5 Re: electric arch going from belt to any ground when engine is running
    Jul 2010
    TX
    no cause i would think any liquid or gel would cause archs to
  6. #6 Re: electric arch going from belt to any ground when engine is running
    no its a Di-electric grease that stops the arch.
  7. #7 Re: electric arch going from belt to any ground when engine is running
    Jul 2010
    TX
    so 3800's normally arch at the plugs and thats why they sell the grease to prevent it?
  8. #8 Re: electric arch going from belt to any ground when engine is running
    i think on all cars they can arch. I use it to prevent it. They come in little pouches at the checkout counter and a pouch is only like .99 cents. it has enough grease to do like 3-4 spark plug changes. just put a little grease on the inside of the boot or right on top of the spark plug where the boot go's over it.
    But putting this grease on the plugs might not help with that other arch problem you are having, but putting the grease on the plugs is still a good idea.
  9. #9 Re: electric arch going from belt to any ground when engine is running
    Jul 2010
    TX
    do u know if that small arch reduces the spark that goes into the spark plug electrode
  10. #10 Re: electric arch going from belt to any ground when engine is running
    i dont know, hopefully others will chime in about that
  11. #11 Re: electric arch going from belt to any ground when engine is running
    Jul 2010
    TX
    yea hopefully. though that other arch will probably remain a mystery forever cause everybody i have asked has never heard of such a thing
  12. #12 Re: electric arch going from belt to any ground when engine is running
    SE Level Member 3800GEN2GPGT's Avatar
    Aug 2011
    Norwalk Ca
    Quote Originally Posted by chev1988rolet View Post
    I realize that this is an old thread but I have seen this before. I would try running the car with out the serpentine belt to see if there is still arcing. If there is no arcing then I would check and or replace the harmonic balancer.
    Another way to prove this is to take some "white out" (ENGINE NOT RUNNING) Put a mark on the outter ring of the dampner pulley and a mark on the timing cover. (like a TDC mark)
    Now get a timing light and hook it up to the #1 spark plug wire and start the vehicle.
    Point the timing light at the marks that you made. (the marks should be in line)
    Have a helper or you rev the engine kinda agressive 2-3X.
    Use the timing light to look at the marks. (If the marks are no longer in line then the dampner pulley is debonded and needs to be replaced)
    Oh also make sure that the ground strap from the engine to the firewall is connected.
    Hope this helps
    Randy & Jill
    3800GEN2GPGT
    ASE Master Tech
    L1 Certified
    ASE Master Machinist
  1. Running without SC belt
    By gahris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2009, 08:37 PM
  2. Engine wiring harness ground location?
    By PCweber in forum General Tech Discussion
    Last Post: 09-24-2009, 01:10 PM
  3. Running a GTP without belt?
    By Black18Ice in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2009, 12:51 PM
  4. Engine Ground to Chassis wire
    By AlmightyBirdman in forum Audio, Security & Visual Electronics
    Last Post: 06-18-2008, 07:39 AM
