Thread: 0-60 times
Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
  1. #21 Re: 0-60 times
    SE Level Member 02PrixGT's Avatar
    Canada
    look into it sounds good how much roughly
  2. #22 Re: 0-60 times
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    used $175 ish
    new $225 ish
    Retired
    Turbo'd
  3. #23 Re: 0-60 times
    GTP Level Member AjL227's Avatar
    IL
    Quote Originally Posted by GMCARS4LIFE View Post
    Good time for the mods I bet now you are in the 4's with a good launch
    That'd be nice, but I guarantee I won't run mid 12's like Victor.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  4. #24 Re: 0-60 times
    I'm suprised you haven't dropped to a smaller pulley with a Full-Size IC and a dyno tune with headers...I'd be rocking somewhere in the 3.2" range with bigger injectors. I don't see how 12's is out of reach if you know how to drive and you get it dialed in right.
  5. #25 Re: 0-60 times
    IL
    I originally wanted to go for a 3.2", but figured I'd hold off on bigger injectors at the moment. Ever since the headers, I've been getting an intermittent P0133 02 Circuit Slow Response DTC. The sensor has been swapped for two new ones and it hasn't fixed the problem. Sometime after I fix this issue, I will be converting to E85.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  6. #26 Re: 0-60 times
    SE Level Member Milestone's Avatar
    May 2008
    The fastest I recorded on my aeroforce was a 4.5
    Modded.......Yes sir
  7. #27 Re: 0-60 times
    Ridin' the Blue IrishNation24's Avatar
    San Diego, CA
    those aeroforces arent accurate you know.
    http://www.grandprixforums.net/membe...lbums-car.html
    2001 GTP special edition. lots of mods.
    1994 Greenwood C4 LT1-traded in for 6700 with 160K miles for....
    a 2004 LE MANS COMMEMORATIVE EDITION Z06 23K MILES.
  8. #28 Re: 0-60 times
    San Diego, CA
    Quote Originally Posted by Milestone View Post
    what are your mods? not trashing, just want to find out, cuz right now your saying that your 0-60 is faster then an early 2000s z06 which was 4.6ish, and also a early 90s zr1, which one of my old bosses had(91 to be exact), and it was fast as ****... seems a little odd, but thats why im asking what your mods are.
  9. #29 Re: 0-60 times
    Quote Originally Posted by IrishNation24 View Post
    my 550 ft lbs of torque to the tranny according to my aeroforce is a testament to that.
  10. #30 Re: 0-60 times
    San Diego, CA
    ****, thats nothing, i got over 900 ft lbs/torque and HP.!! lol
  11. #31 Re: 0-60 times
    May 2008
    X-P cam
    Four .052 layer Cometic head gaskets
    Fully built tranny
    3.29 gear swap
    Ported and Polish Heads
    Tapered and faced valves
    3.2 inch supercharger pulley
    4 inch Fenderwell Intake
    Digital Horsepower custom pcm
    Alternator Voltage Booster
    Alternator Rewire Kit
    Hardned 4th clutch shaft
    Hardned input shaft
    Hardned gundrilled output shaft
    Throttle body spacer
    PRJ 10.5 mm race wires
    NGK Iridium spark plugs
    Throttle body heat shield
    180 degree thermostat
    Ported Supercharger
    Ported Lower Intake Mainifold
    Racetronix High Volume Fuel Pump
    Fuel Pump Rewire Kit
    ZZP Performance Shift Kit
    HPTUNERS tuning software
    39# fuel injectors
    Zex Nitrous Wet kit
    I consistantly run 12.9 in the quarte without spray, and dynoed 295whp and 330lb feet of torque without spray on a mustang dyno. Here is a link to my cardomain page. And rate my ride while you're at it.
    http://www.cardomain.com/ride/2547948
  12. #32 Re: 0-60 times
    May 2008
    I'm also spraying 100 shot
  13. #33 Re: 0-60 times
    My tranny is sucking wind so I don't think I have a time to post...so 10s is probably the best I could do right now LOL
  14. #34 Re: 0-60 times
    San Diego, CA
    hmmmm still....... faster then a zr1? i dont know...
  15. #35 Re: 0-60 times
    405 hp at the crank = 365-345 WHP in those ZR1's.
    with 295 WHP in a GP you should be around 5 seconds according to these 0-60 calculators.
  16. #36 Re: 0-60 times
    San Diego, CA
    um... duh.
  17. #37 Re: 0-60 times
    its AWDsome JarenSTi's Avatar
    Hawaii
    mine goes 0-60 in 4.5..... minutes
    2002 WS.6- exhaust, 42k miles
    2005 Subaru WRX
    2002 GT - sold
  18. #38 Re: 0-60 times
    San Diego, CA
    lol nice
  1. Not exactly kills but times
    By Louie3 in forum Track Sessions and Kills
    Last Post: 05-12-2010, 07:29 AM
  2. new list soon...what times
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 11-04-2009, 11:07 AM
  3. Reminicing of old times...
    By PonchoDvr4Lfe in forum Off Topic Discussion
    Last Post: 09-14-2009, 09:59 PM
  4. New times @ ATCO
    By QwikGT in forum Off Topic Discussion
    Last Post: 12-06-2008, 09:15 AM
  5. What times will you be happy with ?
    By Meemperor in forum Off Topic Discussion
    Last Post: 02-17-2008, 04:43 PM
