Thread: Need bolt size assistance
Results 1 to 8 of 8
  1. #1 Need bolt size assistance
    Apr 2009
    stockton ca
    Im doing the front seal tomorow and I cant fint the bolts i used last time for the harmonic balancer the 3 that screw into the balancer to use with the puller
    i know they are 3 " long couldnt find the thread that had the thread pitch and size
  2. #2 Re: Need bolt size assistance
    Jan 1970
    Maquoketa, Iowa
    Before you get too far into this I would try out the bolts that came with your puller or the ones you bought for it just to make sure everything is good. The GM balancer (3300 & 3800 engines I believe) uses a non-standard thread pitch. In my research I came up two sizes, 1/4-28 and M6 x 1.0mm. The M6 will screw in partially but perhaps not enough to pull the balancer off and if you force it, you will likely booger up the threads and I don't think you will find a tap long enough to clean up the threads. Once you get the balancer off, you could retap the threads and personally if one could do that I would drill and tap them for 1/4-20. If I had had the time I would have done just that. 1/4-20 grade 8 bolts are a whole lot easier to find than 1/4-28.
  3. #3 Re: Need bolt size assistance
    Apr 2009
    stockton ca
    1/4-28 thanks i have it on here in a couple posts just didnt feel like searchin through them
    i also know a few hardware stores that have them
  4. #4 Re: Need bolt size assistance
    Donating Users wulfpack06's Avatar
    KCMO
    use 8 inch three jaw puller and a socket
  5. #5 Re: Need bolt size assistance
    Charles City, IA
    Quote Originally Posted by wulfpack06 View Post
    Or do it the right way.
    SMGPFC Two Nipple General
  6. #6 Re: Need bolt size assistance
    Apr 2009
    stockton ca
    The right way is fine with me
  7. #7 Re: Need bolt size assistance
    KCMO
    let me ask you how thats the wrong way? it wont damage anything.....at all not even taking a chance in pulling the threads you guys use in the harmonic balancer
  8. #8 Re: Need bolt size assistance
    Apr 2009
    stockton ca
    Well for one i dont have a 3 jaw puller i have a harmonic balancer puller
  1. 97-03 GTP EGR tube bolt size?
    By AnotherGTP in forum General Tech Discussion
    Last Post: 01-25-2010, 11:27 PM
  2. Bolt size needed
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 01-13-2010, 10:27 AM
  3. Bolt Size
    By GaBear in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2009, 06:40 AM
  4. S/C bolt size question
    By TDCRacing in forum General Tech Discussion
    Last Post: 01-20-2009, 12:36 PM
  5. Exhaust bolt size
    By the1euge in forum General Tech Discussion
    Last Post: 07-11-2008, 09:59 PM
