Let me start by saying I'm am not a car guy by far, my skills are tinker with beginners stuff at best, and even that's a reach
I'm having a rough week, first my wipers won't squirt solvent out of them, I don't even hear the noise of the motor or whatever squirts the solvent out. The wipers go back and forth fine, but no liquid comes out. The weather is above freezing now, and I looked under the hood, the reservoir is filled up 3/4 and it appears the hose leading from it to the wipers is attached. Is there actually a motor or something that does the squirting? are those expensive to have replaced by a pro?
Also, the knob for my blower has come off. the center plastic piece on the inside cracked in half, so i krazy glued it back on, but when i attempted to re-attach it, lining the button up with the little notch on where the knob goes back into, if I attached it that way, the knob would be pointing straight down. I thought maybe it just rotates but I wasn't able to budge the part with the notch still attached to the car. I'm guessing I'll have to have someone fix that as well? is that expensive to do also?
