Magnaflows,U-bend Delete, Res delete,S1X cam
Not running 100% yet still have a cam position ciruit problem
and the cam was a bit to close
YouTube - MVI_0212.AVI
yea with a better camera it does sound a lil better but thanks
I just installed my s1x cam as well. I started back off with a stock gtp file, and quickly found out that I had to up the rpm's by 50-100 on idle. I know your loving the lope.
yea but the damn cam position code is causing it to run in limp mode or i have another issue that isnt causing a code
Needs a res. Sounds good at first but gets raspy as **** when you rev it.
I dont mind it so its all good
Yeah dude if it sounds good to you that's all that matters.
it was something that was on the ground
yea i mean its a bit raspy but lower tones if that makes sense
i really like that idling sound, good job you are really gonna like it when you get the bugs out.
mic = clipping due to sound pressure... put the camera further away and try again.
